how to read ky40 mechanical encoder ?
Results 1 to 21 of 21
    Jun 2008
    Varese , Italy
    Default how to read ky40 mechanical encoder ?
    Good day to all of you in this forum.
    I used an optical encoder in the past with pbp and I had good result.
    Now I have a mechanical encoder similar to the ky40 or ky-040 that is widely available on the net.
    I am not able to make it working correctly and still having bad results.
    I did filtered the A and B signals with two 0.1uf and 10k resistors pull_up: no solution up to now.
    Any help on the this matter please ? Or any sample code available ?
    Ambrogio
    Default Re: how to read ky40 mechanical encoder ?
    Is your encoder like this ?
    http://www.ebay.com/itm/400964660325...%3AMEBIDX%3AIT
    These encoders are (supposedly) destroyed by pullup resistors.
    Or is your encoder just a noisey old mechanical switch type?
    Comparators are supposed to be good buffers for mech switches.
    OK I found my answer, Mech. as stated in your post
    You are needing to "debounce" these.
    Jun 2008
    Varese , Italy
    this is my ecoder:
    http://www.ebay.com/itm/1PCS-KY-040-...item27e8f12b89
    Any help , please ?
    Ambrogio
    CAUTION: UNTESTED CODE
    A var portb.6
    B var portb.7
    state var byte
    if(( A == 1)&&(B==1)) then state = 1
    if(( A == 1)&&(B==0)) then state = 2
    if(( A == 0)&&(B==1)) then state = 3
    if(( A == 0)&&(B==0)) then state = 4
    ;pause 100
    if state = 1 then portC = %00000001
    if state = 2 then portc = %00000010
    if state = 3 then portc = %00000100
    if state = 4 then portc = %00001000
    debug "  state = ",#state
    I found this interesting.
    http://makeatronics.blogspot.it/2013...ture-with.html
    is your "re " a 20 count per turn with indents ? the 10 for a $1 ones I got from ebay have enough contact bounce to start a spring factory but the inherent software filtering of the above code does an amazing job on them 1 (4k7 pu r's and .1uFs included). I have not ported this to pbp but have for mikro c and xc8 if that helps
    http://www.circuitsathome.com/mcu/re...age-1#comments
    this link has some other insights
    basically you just need to adjust your re count using this current value / old value matrix (illegal values [bounces] are just ignored )
    Sep 2009
    One of possible ways to implement filter(Not tested)
    OutputValue=0
    Select Case OldValue
    Case 0
    If Current=1 then OutputValue=-1
    If Current=2 then OutputValue=1
    Case 1
    If Current=3 then OutputValue=-1
    If Current=0 then OutputValue=1
    Case 2
    If Current=0 then OutputValue=-1
    If Current=3 then OutputValue=1
    Case 3
    If Current=2 then OutputValue=-1
    If Current=1 then OutputValue=1
    EndSelect
    Jun 2008
    Varese , Italy
    still not able to make my panel encoder working .
    Could someone post the complete code applicable to mechanical encoder like my one please ?
    Thanks in advance.
    regards,
    Ambro
    post the code you are trying , and a bit of info about your re setup .
    does it have detents ?
    how many edges per turn ?
    pull ups ?
    filter caps ?
    pic type ?
    pins used ?
    is not much to work with
    Jun 2008
    Varese , Italy
    Thanks for the assistance.
    My encoder has detents and has about 24 edges per turn.
    I used a pull up of 2x 10 k on both encoder phases and a 2x 0.1uF to ground.
    I am using pic18f452 , xtal=10 Mhz, ppl X 4 to get 40 Mhz clock speed.
    I used RB0 for the "A" phase as shown on the code.
    At the end of the world I am now able to make it working well using the following picbasic program by including Darrel Taylor interrupt routine.
    The program prints counter results on a terminal @ 115200 baud rate 8,n,1.
    Regards, Ambro
    DEFINE OSC 40 ' XTAL= 10 MHZ CLOCK= 40 MHZ
    INCLUDE "MODEDEFS.BAS"
    INCLUDE "DT_INTS-18.bas" ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts
    INTCON2.BIT6=0 ' interrupt from 1 down to 0 on RB0
    CNT VAR WORD ' COUNTER TO BE DISPLAYED ON TERMINAL
    CNT= 32000
    CNTOLD VAR WORD
    CNTOLD=32000
    B VAR PORTD.1 ' encoder B PHASE
    A VAR PORTD.0 ' encoder A PHASE
    ' DEBUG INTERFACE \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\
    '' Set Debug pin port ________________________________________
    DEFINE DEBUG_REG PORTD
    '' Set Debug pin bit _________________________________________ PIC_PIN_30
    DEFINE DEBUG_BIT 7
    '' Set Debug baud rate _________________________________________
    DEFINE DEBUG_BAUD 115200
    '' Set Debug mode: 0 = true, 1 = inverted ______________________
    DEFINE DEBUG_MODE 1
    DEBUG 13,10,13,10, " START OF PROGRAM ", 13, 10, 13, 10
    ADCON1=7 ' all digital !
    INT_Handler INT_INT, _ToggleLED1, PBP, yes
    @ INT_ENABLE INT_INT ; enable external (INT) interrupts
    PAUSE 1
    IF CNT <> CNTOLD THEN
    DEBUG DEC CNT,13,10
    CNTOLD=CNT
    Jun 2008
    Varese , Italy
    sorry for not having paste the complete code...
    CNT= 32000
    CNTOLD VAR WORD
    CNTOLD=32000
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_MODE 1
    PAUSE 1
    DEBUG DEC CNT,13,10
    CNTOLD=CNT
    GOTO Main
    ToggleLED1:
    if b=0 then cnt=cnt-1
    IF B=1 THEN CNT=CNT+1
    @ INT_RETURN
    ToggleLED1:
     @ INT_RETURN
    I found that strategy gave quite disappointing results , was jerky missed counts and had sudden and unexpected direction reversals. there are better ways
    Jun 2008
    Varese , Italy
    I am sorry Richar for having posted the file that is not the final one:
    please change the following:
    shAll be:
    A VAR PORTB.0
    This is the interrupt input !
    I would be happy to know ...
    Thanks and regards,
    Ambrogio
    Jun 2008
    Varese , Italy
    I did capture the output of the terminal printout for a better check.
    There are about 200 changes of the cnt obtained by "manually" turning the encoder knob on my control panel. Probably sometims cw and ccw.
    I noted very few spikes : I am not shure if they are due to the time required for the serial port output or to the encoder software.
    Any improvement to the program is very much appreciated.
    I am really searching for a good solution.
    regards,
    Ambrogio
    I do it this way
    enc pins must be sequential and on same port
    both enc pins must be able to generate an interrupt (ioc on neg and pos edge is best , ioc, rac,rbc on neg or pos edge will work as will int0 int1)
    enc pins must be pulled up (10k) and have 0.1uF filter caps
    I have an asm version that's 100 bytes smaller and has about 1 tenth of the irq latency and is much faster too
    '*  Name    : rotary encoder.BAS                                *
    '*  Author  : richard                                           *
    '*  Notice  : Copyright (c) 2013                                *
    '*  Date    : 9/4/2013                                          *
    '*  Version : 1.0    16f1825                                    *
    '*  Notes   :  enca porta.2 encb porta.3                        *
    '*          :   note mclr disabled ,full quad decode            *
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_ON  &  _PWRTE_ON  &  _MCLRE_OFF  & _CLKOUTEN_OFF
    include "dt_ints-14.bas"
    include "REENTERPBP.bas"
    asm
    INT_LIST macro
          INT_HANDLER IOC_INT, _enc_isr,pbp,NO
     INT_CREATE
    DEFINE OSC 32
       OSCCON=$70
       ANSELA=0
       OPTION_REG.6=0
       ev    VAR BYTE bank0
       cnt   VAR WORD bank0
       TMP   VAR BYTE bank0
       enca  VAR porta.2
       encb  VAR porta.3
       TRISA = 111110
       lata.0=1
       IOCAP=12    ;enca porta.2 encb porta.3  pos edge trigger
       IOCAN=12    ;enca porta.2 encb porta.3  neg edge trigger
       pause 4000
       serout2 PORTA.0,84,[ "ready",13,10]
       IOCAF=0
       INTCON=$C8
    mainloop:
     serout2 PORTA.0,84,[13,10, "C",#CNT]
     goto mainloop
    enc_isr:
    ev=ev<<2              ;shift last reading into position
    ev=ev|((porta&12)>>2)  ;read enc pins 2,3  mask off others then  combine this reading with last reading
    LOOKUP (ev&$f),[0,255, 1, 0, 1, 0, 0, 255, 255, 0, 0, 1, 0, 1, 255, 0],tmp ;lookup the decision matrix
    if tmp then         ; decide to inc , dec or ignore
     if tmp.7 then
       cnt=cnt-1
        cnt=cnt+1
    intcon.0=0                   ; clean up and exit
    iocaf=0
    @ INT_RETURN
    Jun 2008
    Varese , Italy
    Thanks Richard for the code.
    I am just a little bit busy on these days and so I plan to try your code on next days.
    As you have seen I am using pic18f452: Is your code applicable to this micro ?
    If no, what should I modify or adapt ?
    Ambrogio
    for a pic18f452 you need to use RBC_INT for best results and pins portb.4,5 or portb.6,7 or portb.5,6
    this line needs to match chosen p1ns
    for pins portb.4,5 it would be
    ev=ev|((portb&48)>>4)
    INT_LIST macro
     INT_CREATE
    would be
    INT_LIST macro
          INT_HANDLER RBC_INT, _enc_isr,pbp,NO
     INT_CREATE
    IOCAF=0
    INTCON=$C8
    would be
    dummy_var = portb
    INTCON=$C8
    any references to IOCAF need to be deleted , trisb must be appropiate
    Jun 2008
    Varese , Italy
    Hi Richard,
    I am going to modify my previous program with your indications.
    Probably I did something wrong and it is not working.
    I am attaching the full code : could you please have a look of it ?
    Thanks again for the assistance
    regards,
    Ambro
    I would do it like this
    '*  Name    : pic controlled power supply                       *
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/09/2015                                        *
    '*  Notes   : pic18f452 10mhz x 4 pll = 40 MHZ                  *
    ';Program Configuration Register 1H
    @  __CONFIG    _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
    ';Program Configuration Register 2L
    @  __CONFIG    _CONFIG2L, _BOR_OFF_2L & _BORV_20_2L & _PWRT_ON_2L
    ';Program Configuration Register 2H
    @  __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    ';Program Configuration Register 3H
    @  __CONFIG    _CONFIG3H, _CCP2MX_OFF_3H
    ';Program Configuration Register 4L
    @  __CONFIG    _CONFIG4L, _STVR_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    ';Program Configuration Register 5L
    @  __CONFIG    _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    ';Program Configuration Register 5H
    @  __CONFIG    _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    ';Program Configuration Register 6L
    @  __CONFIG    _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    ';Program Configuration Register 6H
    @  __CONFIG    _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    ';Program Configuration Register 7L
    @  __CONFIG    _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    ';Program Configuration Register 7H
    @  __CONFIG    _CONFIG7H, _EBTRB_OFF_7H
    CNT= 32000
    CNTOLD VAR WORD
    CNTOLD=32000
    counter VAR WORD
    counter= 32000
    ' DEBUG INTERFACE  \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_MODE 1
    DEBUG 13,10,13,10, " PROGRAM IS STARTING...", 13, 10, 13, 10
            INT_Handler    RBC_INT,  _enc_isr,   PBP,  NO
    '@   INT_ENABLE   RBC_INT     ; enable external (INT) interrupts
       ev    VAR BYTE BANK0
       TMP   VAR BYTE BANK0
       enca  VAR portb.4
       encb  VAR portb.5
       TRISA = 255
       lata.0=1
       tmp = portb  ;; read portb to establish pin change status
       INTCON=$C8  ; enable RBC_INT and clear rbcif
      PAUSE 1000
      gosub get_cnt:
      IF counter <> CNTOLD THEN
         DEBUG DEC CNT,13,10
         CNTOLD=counter  ENDIF
    GOTO Main
    enc_isr:
    ev=ev|((portb&48)>>4)  ;read enc pins 4+5  mask off others then  combine this reading with last reading
     if tmp.7 then
       cnt=cnt-1
        cnt=cnt+1
    @ INT_RETURN
    get_cnt:       ;  cnt is not atomic   this is needed to avoid rollover miss reads
    intcon.3=0
    counter=cnt
    intcon.3=1
    Jun 2008
    Varese , Italy
    Thanks Richard,
    Your program compiles well.
    I do have the follwing :
    32009
    32005
    32009
    32013
    32017
    32021
    32033
    32042
    32073
    32113
    32153
    32173
    32197
    32209
    32233
    32257
    32221
    32199
    32161
    32129
    32101
    32065
    32061
    32057
    32053
    32045
    32041
    32040
    32037
    32013
    31999
    31997
    I have changed the encoder too but not working...
    Ambro
    the isr counts edges , an indented re has 4 edges per indent . you would expect to increment counter by 4
    don't forget the display routine and the isr are asynchronous .
    if you are trying to count indents then
     cnt_f var bit
      PAUSE 10
      IF cnt_f THEN
     gosub get_cnt:
         DEBUG DEC counter,13,10
    GOTO Main
    enc_isr:
        ev=ev|((portb&48)>>4)  ;read enc pins 4,5  mask off others then  combine this reading with last reading
        LOOKUP (ev&15),[0,255, 1, 0, 1, 0, 0, 255, 255, 0, 0, 1, 0, 1, 255, 0],tmp;lookup the decision matrix
            if tmp.7 then
               cnt=cnt-1
               cnt_f=1
                cnt=cnt+1
                cnt_f=1
    @ INT_RETURN
    get_cnt :
    intcon.3=0
        counter=cnt/4
        cnt_f=0
      intcon.3=1
    Jun 2008
    Varese , Italy
    Richard:
    for each one click ( or detent ) it prints four numbers.
  1. Question about mechanical relay
    Last Post: - 1st October 2012, 11:37
  2. Mechanical question
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 11th October 2011, 06:41
  3. Probe to read quadrature encoder with DT_INT need help
    By phoenix_1 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 21:43
  4. Mechanical question
    By selbstdual in forum Off Topic
    Last Post: - 8th February 2008, 15:34
  5. Replies: 6
    Last Post: - 14th October 2005, 20:41
