dht22 using bit field array and ext references
Results 1 to 5 of 5
    Default dht22 using bit field array and ext references
    I thought I would have a go at making a better dht reading routine , note this code uses a 64mhz clk that conveniently provides a 1uS increment with for a timer prescale of 16. if you choose a different clk then the timer prescale and or the timing limits will need adjusting.
    Default Re: dht22 using bit field array and ext references
    Hi Richard,
    Have you tested the length of cable/wire that can reliably be used with these sensors? And if you have, does it make a difference if the resistor is at the sensor or at the PIC?
    no not at all I have the unit mounted on the cpu pcb with no pull up resistor at all , just using wpub and a 3.3v rail. The data sheet (am2302) implies that 100m transmission is possible with a 1k pull up and shielded cable . not really sure why the pull up resistor location would make a difference assuming that the cable resistance is very low compared to the pull up value . my remote sensor (outside) is a wireless connection with a rfm69cw , so cable transmission is not something I have looked into
    Thanks Richard. I have used the DHT11 with 50 foot of wire and the resistor at the MCU. My boy is trying a DHT22 with the resistor at the module. He is getting strange readings. I have not seen his setup yet to figure out the problem.
    with a little bit more code now it can do dht11 and dht22 sensors just by setting a var sens_type to 11 or 22
    see this thread for adjusting timers for a different fosc
    http://www.picbasic.co.uk/forum/showthread.php?t=19873
  1. DHT22, AM2302 and pic18F2320
    By bitmaniac in forum mel PIC BASIC Pro
    Last Post: - 15th November 2015, 01:42
  2. ShiftIn to array of bits using EXT modifier?
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th March 2011, 15:30
  3. Symbolic bit references for SFR's
    By khaynes in forum PBP Wish List
    Last Post: - 18th March 2008, 23:17
  4. Help with bit array
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 27th August 2006, 18:31
  5. Problem with bit array
    Last Post: - 12th May 2005, 18:03
