dht22 using bit field array and ext references
Results 1 to 5 of 5
Threaded View
    Default dht22 using bit field array and ext references
    I thought I would have a go at making a better dht reading routine , note this code uses a 64mhz clk that conveniently provides a 1uS increment with for a timer prescale of 16. if you choose a different clk then the timer prescale and or the timing limits will need adjusting.
  1. DHT22, AM2302 and pic18F2320
    By bitmaniac in forum mel PIC BASIC Pro
    Last Post: - 15th November 2015, 01:42
  2. ShiftIn to array of bits using EXT modifier?
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th March 2011, 15:30
  3. Symbolic bit references for SFR's
    By khaynes in forum PBP Wish List
    Last Post: - 18th March 2008, 23:17
  4. Help with bit array
    By Dick M in forum mel PIC BASIC Pro
    Last Post: - 27th August 2006, 18:31
  5. Problem with bit array
    Last Post: - 12th May 2005, 18:03
