Serout2 on LCD Shows Junk Characters
Results 1 to 11 of 11
    Default Serout2 on LCD Shows Junk Characters
    I'm trying to work out whether the code below is accurately producing 0-255 values for the ADCIN command which I'm then using in conjunction with Darrel's SPWM_Int.bas, but I can't tell because my Scott Edwards Electronics ILM-216 serial LCD just shows gobbledy-gook. I've jumpered pins 6 & 8 on the LCD to get 9600bps but it's no better than the default 2600 baud.
    Can anyone help me out? I bought this serial LCD as my previous one was a parallel one which uses too many pins but it's not much good to me if it can't help me debug.
    Scott Edwards Electronics data sheet for the ILM-216 can be seen here.
    ' Pin Connections
    ' RA0                        -> Middle arm of trim pot
    ' RC0                        -> LED1
    ' RC1                        -> LED2
    ' RC2                        -> LED3
    ' RC4                        -> Serial LCD output
    DEFINE OSC          16      ; Set oscillator 16Mhz
    ;DEFINE OSC           4      ; Set oscillator 4Mhz
    DEFINE ADC_BITS      8      ; Set number of bits in result
    DEFINE ADC_SAMPLEUS  5      ; Set sampling time in uS
    DEFINE ADC_CLOCK     3      ; Set clock source (3=rc)
    ' Device Fuses
       __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF
       __config _CONFIG2, _PLLEN_OFF & _STVREN_ON & _BORV_LO & _LVP_OFF
    #DEFINE USE_LCD_FOR_DEBUG   ; comment out for non-debug use
    ' Initialization
    OSCCON   = %01111000        ' 16MHz internal osc
    ;OSCCON   = %01101000        ' 4MHz internal osc
    ; Use PortA.0 (AN0) for ADCIN (trim pot reading)
    ANSELA   = %00000001        ; Analog on PORTA.0 (AN0) only
    TRISA    = %00000001        ; Input on PORTA.0 (AN0) only
    ;ADCON1   = %01110000        ; Left-justified results in 8-bits; Fosc/8 (2uS @ 4Mhz)
    ADCON1.7 = 0                ; Left-justified results in 8-bits; Fosc/8 (2uS @ 4Mhz)
    ANSELC   = 0                ; Diginal only for all PortC pins
    TRISC    = %00000000        ; Make all PORTC pins output
    #IFDEF USE_LCD_FOR_DEBUG
        LCD_PIN    VAR PORTC.4  ' Alias PORTC.4 as "LCD_PIN"
        LCD_INST   CON 254      ' instruction
        LCD_CLR    CON 1        ' Clear screen
        LCD_L1     CON 128      ' LCD line 1
        LCD_L2     CON 192      ' LCD line 2
    ;    LCD_BAUD   CON 16780    ' Baud rate/mode 2600bps for ILM-216 2x16 character display
        LCD_BAUD   CON 16468    ' Baud rate/mode 9600bps for ILM-216 2x16 character display
        LCD_PACE   CON 1        ' Optional pace value
    #ENDIF
    ' Includes
    INCLUDE "DT_INTS-14.bas"            ; Base Interrupt System
    INCLUDE "SPWM_INT.bas"              ; Software PWM module
    DEFINE SPWM_FREQ  200               ; SPWM Frequency
    DEFINE SPWM_RES   256               ; SPWM Resolution
    DutyVars   VAR BYTE[3]              ; DutyCycle Variables
      DutyVar1 VAR DutyVars[0]          ; group them in an array for easy access
      DutyVar2 VAR DutyVars[1]          ; with FOR loops etc.
      DutyVar3 VAR DutyVars[2]
    SPWM_LIST  macro                    ; Define Pin's to use for SPWM
         SPWM_PIN  PORTC, 0, _DutyVar1  ; and the associated DutyCycle variables
         SPWM_PIN  PORTC, 1, _DutyVar2  ; Notice the underscore before variables
         SPWM_PIN  PORTC, 2, _DutyVar3
      SPWM_INIT  SPWM_LIST              ; Initialize the Pins
            INT_Handler   TMR1_INT,  SPWMhandler,  ASM,  yes
        INT_CREATE                      ; Creates the interrupt processor
    @ INT_ENABLE  TMR1_INT              ; enable Timer 1 interrupts
    adval       VAR  WORD       ; stores ADCIN results
    oldDutyVar1 VAR  WORD
    ;_____________________________________________________________________________
    DutyVar1 = 0
    DutyVar2 = 25
    DutyVar3 = 255
        serout2 LCD_PIN, LCD_BAUD, LCD_PACE, [LCD_INST, LCD_CLR]     ; clear screen
        pause 5
        serout2 LCD_PIN, LCD_BAUD, LCD_PACE, ["DutyVar1:", DEC DutyVar1, "         "]
    #ENDIF
       ADCIN 0, adval
       if adval <> oldDutyVar1 then
          oldDutyVar1 = adval
          DutyVar1 = adval
              pause 5
          #ENDIF
       EndIf
       Pause 100
    Goto Main
    Default Re: Serout2 on LCD Shows Junk Characters
    Ross,
    You can't use software timed serial routines when using interrupts.
    You will need to use the USART and HSEROUT.
    Aug 2008
    Portugal
    Hi RossWaddell,
    I used this LCD in the past and i had some problems with interrupts. If you are outputing something to the LCD and if an interrupt occurs, the data gets corrupted. If possible, you must disable the interrupt, then send the data with the serout command, and then enable interrupt, of course, if it is allowed to do in your program. When i don't use interrupts, no problem working with this LCD, with serout, serin, serout2, serin2, hserout and hserin!!
    EDIT: grrr... Darrel.... get it first!!!!
    Thanks and Regards;
    Gadelhas
    Thanks Darrel & Gadelhas. Am I right in thinking RA0 is the USART tx pin on the PIC16F1825?
    Aug 2008
    Portugal
    Yes. You can have TX on RA0 or RC4, because in this chips is possible to change between those 2 pins, by controlling the APFCON0 and APFCON1 registers.
    Thanks and Regards;
    Gadelhas
    If I'm using RA0, do I need to set those registers? Because without them the screen is completely blank:
    '*  Name    : Test_SPWM.pbp                                     *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 9/30/2006                                         *
    ; LCD serout2 command won't work when using interrupts; need to use
    ; HSEROUT on chip's USART tx pin instead.
    ' Pin Connections
    ' RA0                        -> Serial LCD output
    ' RA1                        -> Middle arm of trim pot (AN1)
    ' RC0                        -> LED1
    ' RC1                        -> LED2
    ' RC2                        -> LED3
    DEFINE  HSER_TXSTA   20h    ; Set transmit status and control register
    DEFINE  HSER_BAUD    2400   ; Set baud rate
    ' Device Fuses
    ' Initialization
    ; Use PortA.1 (AN1) for ADCIN (trim pot reading)
    ANSELA   = %00000010        ; Analog on PORTA.1 (AN1) only
    TRISA    = %00000010        ; Input on PORTA.1 (AN1) only
    ;    LCD_BAUD   CON 16468    ' Baud rate/mode 9600bps for ILM-216 2x16 character display
    #ENDIF
    ' Includes
    DutyVar1 = 0
    DutyVar2 = 25
    DutyVar3 = 255
        HSEROUT [LCD_INST, LCD_CLR]
        pause 5
        HSEROUT ["DutyVar1=", DEC DutyVar1, 13, 10] ' Send text followed by carriage return and linefeed
    #ENDIF
       ADCIN 1, adval
          oldDutyVar1 = adval
          DutyVar1 = adval
             HSEROUT [DEC DutyVar1, 13, 10] ' Send text followed by carriage return and linefeed
          #ENDIF
       EndIf
       Pause 100
    Goto Main
    Edit: Adding
    APFCON0.2 = 1               ; Tx on RA0
    makes the screen not blank, but it's still gobbledy-gook.
    Aug 2008
    Portugal
    try with APFCON0.2 = 1, because the chip is initialized with TX on the RC4 pin, (APFCON0.2 = 0), so you must change it. datasheet page 123.
    Thanks and Regards;
    Gadelhas
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 19:53
  2. LCD Low Power
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2012, 01:05
  3. Interfacing a Nokia 6233 LCD display
    By dancorneanu in forum General
    Last Post: - 13th November 2012, 15:30
  4. Only the first 8 characters.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2009, 02:43
  5. ascii characters to hex
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 05:06
