Help reading schematic
Results 1 to 16 of 16
    Oct 2010
    Saskatoon Saskatchewan Canada
    Default Help reading schematic
    I'm having a little trouble reading this schematic mostly with the FDC6420C mosfets. I know there are only 4 (says in parts required) and are 6 pin. I just don't know which ones get paired up. I'm used to more of automotive wiring diagrams.
    Also on the BAT54S diodes, are these 3 pin? If so would someone have a full part number as I already have 2 pin ones.
    Welcome to the forum.
    http://www.fairchildsemi.com/ds/FD/FDC6420C.pdf
    http://www.fairchildsemi.com/ds/BA/BAT54.pdf
    The FETs are paired N and P. The diodes are three pins. The data sheets show all of that.
    Automotive type???
    Automotive type???
    Hi, Dave
    Automotive type electrical SCHEMES ...
    sure they're somewhat different ...
    May 2008
    Italy
    Any schottky diode of 500 mA 30 volts will be ok as a replacement.
    Every FDC6420C should be regarded as half bridge. It incorporate both the N & P channels mosfet.
    The circuit function is a driver for a bi-polar stepper motor with 12 volts @ 2 Amps max per winding.
    Cheers
    Al.
    Oct 2010
    As an automotive service technician, just more used to their type of wiring diagrams. They just don't show a single component in two parts. Mostly just a box or dotted line around it to show you which module your looking at.
    For the mosfets I'm just not sure which gets paired up. For example does Q3:A go with Q5:B or is it Q6:B?
    I'm beginning to wonder if I accidentally got the wrong diodes shipped to me. I ordered BAT54SCT-ND SOT23-3 from Digikey and got a two pin diode with 2002 written on top.
    I'm reconstructing an instrument cluster to fit into my classic truck cause aftermarket metric guages are almost non existant and I want all 6 guages. I'm going to be using Fraen AMD 6405-1512 stepper motors (5v 22ma).
    An "A" gets paired with a "B" or N with a P.
    Sounds like they may have shipped the wrong diode. SOT23-3 with two pins?
    Aug 2010
    Maryland, USA
    Quote Originally Posted by 51dueller View Post
    I'm not sure how far down this road you are, but this circuit is way bigger then you need for this motor. Now of course it should work, but there are smaller simpler solutions if you are intrested.
    -Bert
    Hi, 51
    a look here ???
    http://www.sportdevices.com/ignition/tacho.htm
    Ok, not bipolar stepper ... but minor mod.
    Aug 2010
    Maryland, USA
    Wow, have to thank all of you. I bet I have read that app note 3 or 4 times in the past. Problem was, when I read it I wasn't looking for a bi-polar drive. Now for the past 5 months I have been putting together a 6 axis drive for 2A bi-polar/uni-polar steppers. I settled on a uni drive for convineance and price. This is a worthwhile drive circuit, deserving much deeper look.
    So far, it looks to be both cost effective and manufacturable!
    So again, thanks! Now as I develop this further, should I start a new thread or continue this one?
    -Bert
