USART interrupt not interrupting right
Results 1 to 13 of 13
    Morpheus's Avatar
    Morpheus Guest
    Unhappy USART interrupt not interrupting right
    Hi All!
    I'm working with a 16f628A
    I wrote a "simple" code, the interrupt has just to turn on a led when a 9-bit char with the 9th bit enabled is received on the usart rx port.
    the main program just make blinking a led.
    the results are that if I receive an address(8 bit char with the 9th bit set), the blinking led remains on(or off) doubling the time(2 secs instead 1), and the led that the interrupt had to turn on, remains off.
    I'll post my code.
    CODE:
    INCLUDE "MODEDEFS.BAS"
    TRISA=%11110000
    TRISB=%00000010
    cmcon=7 ' predispone la portaA come I/O digitali
    'INTCON ( Interruption Control register )
    intcon.7=1 'GIE : Global Interrupt Enable bit
    intcon.6=1 'PEIE : Peripheral Interrupt Enable bit ( This bit should be set when using the CCP interruption so on )
    intcon.5=0 'T0IE : TMR0 Overflow Interrupt Enable bit
    intcon.4=0 'INTE : RB0/INT Interrupt Enable bit
    intcon.3=0 'RBIE : RB Port Change Interrupt Enable bit
    intcon.2=0 'T0IF : TMR0 Overflow Interrupt Flag bit
    intcon.1=0 'INTF : RB0/INT Interrupt Flag bit
    intcon.0=0 'RBIF : RB Port Change Interrupt Flag bit
    'definisco il registro di ricezione RCSTA
    rcsta.7=1 'SPEN serial port enable bit
    rcsta.6=1 'RX9 9-bit receive enable bit
    rcsta.5=0 'SREN single receive enable bit
    rcsta.4=1 'CREN continous receive enable bit
    rcsta.3=1 'ADDEN address detect enable bit
    rcsta.2=0 'FERR framing error bit(read only)
    rcsta.1=0 'OERR overrun error bit(read only)
    rcsta.0=0 'RX9D 9th bit of receive data (read only)
    'definisco il registro di trasmissione TXSTA
    txsta.7=0 'CSRC : Clock Source Select bit
    txsta.6=0 'TX9 : 9-bit Transmit Enable bit
    txsta.5=1 'TXEN : Transmit Enable bit
    txsta.4=0 'SYNC : USART Mode Select bit 0=asincrono
    txsta.3=0 ' N/A
    txsta.2=1 'BRGH : High Baud Rate Select bit
    txsta.1=0 'TRMT : Transmit Shift Register Status bit ( Read only )
    txsta.0=0 'TX9D : 9th bit of transmit data. Can be parity bit.
    'PIE1 ( Peripheral Interrupt Enable register ) 8Ch
    PIE1.7=0 'EEIE : EE Write Complete Interrupt Enable Bit
    PIE1.6=0 'CMIE : Comparator Interrupt Enable bit
    PIE1.5=1 'RCIE : USART Receive Interrupt Enable bit
    PIE1.4=0 'TXIE : USART Transmit Interrupt Enable bit
    PIE1.3=0 ' N/A
    PIE1.2=0 'CCP1IE : CCP1 Interrupt Enable bit
    PIE1.1=0 'TMR2IE : TMR2 to PR2 Match Interrupt Enable bit
    PIE1.0=0 'TMR1IE : TMR1 Overflow Interrupt Enable bit
    'azzera tutti i flag di interrupt
    PIR1.7=0
    PIR1.6=0
    PIR1.5=0 'azzera l'RCIF
    PIR1.4=0
    PIR1.3=0
    PIR1.2=0
    PIR1.1=0
    PIR1.0=0
    'DEFINE HSER_BAUD 38400 ' Set baud rate
    'DEFINE HSER_SPBRG 15 ' Set SPBRG directly (normally set by HSER_BAUD)
    'setta la velocità a 38800
    SPBRG.7=0
    SPBRG.6=0
    SPBRG.5=0
    SPBRG.4=0
    SPBRG.3=1
    SPBRG.2=1
    SPBRG.1=1
    SPBRG.0=1
    DEFINE OSC 10
    Enable interrupt
    i VAR WORD
    led VAR BIT
    led2 VAR BIT
    ric VAR BYTE
    on interrupt GoTo indirizzo
    GoTo ricevi
    indirizzo:
    ' HSerin [ric]'riceve un carattere da seriale
    ' IF led2=1 Then
    ' PORTA.0=0:led2=0
    ' Else
    ' PORTA.0=1:led2=1
    ' EndIF
    PORTB.7=1
    Resume
    ricevi:
    For i=1 to 65000
    Next
    IF led=1 Then
    PORTB.6=0:led=0
    Else
    PORTB.6=1:led=1
    EndIF
    GoTo ricevi
    /CODE
    I hope someone can help me..
    Simone
    P.S. Sorry for my english!
    You always want to clear interrupt flag bits before re-enabling interrupts.
    RCIF is the serial receive interrupt flag.
    Since RCIF is read-only, you need to read RCREG until it's empty to clear
    RCIF. You'll also want to clear any over-run conditions.
    OERR VAR RCSTA.1    ' Alias USART over-run bit
    CREN VAR RCSTA.4    ' Alias USART continuous receive enable bit
    RCIF VAR PIR1.5	    ' Alias USART received character interrupt flag bit
    Try adding this to your BASIC interrupt routine.
         DISABLE
    indirizzo:
         PORTB.7 = PORTB.7 ^ 1   ' Toggle LED on entry to int handler
         IF OERR = 1 THEN   ' If over-run, then clear it
            CREN = 0   ' Disable receive
            CREN = 1   ' Re-enable & clear over-run condition
         WHILE RCIF   ' If RCIF is set, then read RCREG until it's clear
            X = RCREG
         WEND
         RESUME
         ENABLE
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Morpheus's Avatar
    Morpheus Guest
    Thank you Bruce for the answer, now the pic is interrupting, but I have a problem reading the register right..
    indirizzo:
        ric = RCREG
        While RCIF                   'to be sure that the register'll be empty the next time I am going to read it
           	ric2=RCREG
        Wend
         IF OERR = 1 Then   ' If over-run, then clear it
         EndIF
         'print the first 3 bit of the received char on three external leds
         PORTA.0=ric.2
         PORTB.7=ric.1
         PORTB.6=ric.0
    	Write 0+X,ric           'write the received byte in the eeprom
    	X=X+1
      Resume
     Enable
    I am just sending to the pic a 9-bit char like this: 1 0000 0001
    the 9th bit generate the interrupt, and "ric" has to be 1.
    so at the end I have to read X locations of my eeprom programmed with a "01h" byte.
    in the fact I have only the 40-50% of the x locations with 01, and the others has a random-like value (FF, E9, 9b, FE......).
    naturally the problem is not on writing the eeprom, because the 3 external led shows that the byte is far from "01h"!!!
    I can't explain why this happens, do you?
    Thanks a lot
    Simone.
    If you need the 9th bit, then simply read it from RCSTA.0 (as shown in your datasheet) before reading RCREG.
    Example;
    Received 9-bit data = %1 1010 0011
    ric var word
    ric.HighByte = RCSTA & %00000001 ' Read RCSTA bit #0 into ric bit #8
    ric.LowByte = RCREG
    ric now contains %0000 0001 1010 0011
    -Bruce
    tech at rentron.com
    Morpheus's Avatar
    Morpheus Guest
    sorry, I think I didn't explain myself well..
    I don't need the 9th bit, it works well 'cause I need it just to interrupt the pic.
    I need to read the correct address, but I don't know why the char is not always correct.
    for example in 10 sended char, 10 times that the pic generates the interrupt and 10 times that i've the rcreg in the var ric. But "ric" contains only 4-5 times the char that I've sent (00000001), the other times it contains random values. The char that I've received is non the one I've sent!!!
    I tryed with the "Hserin [ric]" command instead ric=RCREC, but it's the same.
    I used the Usart port well without interrupt before, with the same speed (38400) and the received char was ALWAYS correct. I can't explain myself why now I've this problem!!
    I took all the last night trying to solve this problem, without success.
    Are your data packets coming in *all together* or is there a delay between each 9-bit packet?
    Are you 100% sure the transmitting device is sending 9-bit packets?
    -Bruce
    tech at rentron.com
    Morpheus's Avatar
    Morpheus Guest
    The device (pc) is sending 9-bit packet,
    I am sure that it works because if I send a packet with the 9th bit =1, it interrupts, if the 9th bit is=0 it don't.
    the device is sending just 1 byte for time. I just made a program that has a button. every click on this button sends a 9-bit packet to the serial port.
    I can choose the byte sent, and I can choose if the 9th bit is set or nope.
    I also tested it with an oscilloscope. And the 9 bits are correct.
    I have used 9-bit, but not for sending *all* of my packets as 9-bits.
    The address is 9-bits. This issues a wake-up call to all slaves on a common serial bus by generating the hardware interrupt.
    All slaves are interrupted, but only the one with the matching address responds.
    The addressed slave then turns off 9-bit address detection (ADEN = 0), drops into a receive *data* routine, receives & buffers data until an EOM (end of message) marked is received.
    All other slave leave 9-bit address detection ON so they will ignore all data being sent to the salve that was addressed.
    Then the addressed slave re-sets back to 9-bit for auto address detection, and carries on until interrupted again.
    Are you sending *all* of your data from the PC in 9-bit packets with a 1 in bit position 8? Or only the first byte, then clearing this position to 0 for the remainder of your packets?
    If you are, are you clearing ADEN after the address to receive data?
    -Bruce
    tech at rentron.com
    Morpheus's Avatar
    Morpheus Guest
    Now I'm not interested on data packets. I'm just trying to address one slave, so the only thing that I'm doing is to send JUST ONE BYTE on the serial port.
    This byte is the address byte. If the slave is addressed, he has to do something(to turn on a led?), otherwise he will resume.
    I tried to do this, but he worked only in the 40% of the sent bytes.
    So I wrote that code to save in the eeprom what char the pic was receiving. And I saw that the char was right only 40% of times.
    For example:
    -1st try
    PC: %1 0000 0001
    PIC: interrupt, read RCREG, received char:%0000 0001 (this is right)
    -2nd try
    PC: %1 0000 0001
    PIC: interrupt, read RCREG, received char:%0110 0111 (????????? whi????)
    -3rd try:
    PC: %1 0000 0001
    -4th
    PC: %1 0000 0001
    PIC: interrupt, read RCREG, received char:%0100 1001 (????????? whi????)
    -5th
    PC: %1 0000 0001
    PIC: interrupt, read RCREG, received char:%0011 0101 (????????? whi????)
    -6th
    PC: %1 0000 0001
    PIC: interrupt, read RCREG, received char:%0111 0111 (????????? whi????)
    and so on...
    The idea of sending the data byte with only 8 bits is ok, but, for the moment I'm just testing the address detection..
    But if I send 1 byte, and when I read it this is not the byte I sent, even if the ninth bit has generated the interrupt, the slave will not work because it thinks it's not addressed!!
    The problem is that I'm expecting a byte in the RCREG and what I find is another one (random?). I don't know if this depends on the registers or what, but testing with an oscilloscope on the USART rx pin, the byte is right, and is just ONE! It's so strange he gives me a completely different value!
    Is possible that when the pic saves the registers going in interrupt, he changes the value of the RCREG?
    Please post the code you're working with, and I'll have a look
    -Bruce
    tech at rentron.com
    Morpheus's Avatar
    Morpheus Guest
    Thank you for your patience..
    TRISA=%11110000
    TRISB=%00000010
    txsta.3=0	' N/A
    PIE1.3=0	' N/A
    PIR1.7=0
    PIR1.6=0
    PIR1.4=0
    PIR1.3=0
    PIR1.2=0
    PIR1.1=0
    PIR1.0=0
    'set the speet to 38800 baud (with a 10Mhz osc)
    SPBRG.7=0
    SPBRG.6=0
    SPBRG.5=0
    SPBRG.4=0
    SPBRG.3=1
    SPBRG.2=1
    SPBRG.1=1
    SPBRG.0=1
    DEFINE OSC 10
    ADEN VAR RCSTA.3
    Enable interrupt
    i VAR WORD
    led VAR BIT
    led2 VAR BIT
    ric VAR BYTE
    ric2 VAR BYTE
    X VAR BYTE
    X=0
    GoTo ricevi
     Disable
    indirizzo:
        ric = RCREG            'store the byte contained on RCREG in "ric" and clear RCREG
        While RCIF               'to be sure that the register'll be empty the next time I'll read it
           	ric2=RCREG
        Wend
    '    ADEN=0
    '    RCIF=0
    EndIF
         'print the 3 lsb of ric into 3 external leds
         PORTA.0=ric.2
         PORTB.7=ric.1
         PORTB.6=ric.0
                 'every time that the pic is interrupted, store the received byte in a location into the eeprom
    	Write 0+X,ric
    	X=X+1          'next time will write the next location
      Resume
     Enable
    ricevi:
    	For i=1 to 65000
    	Next
    		IF led=1 Then
    			PORTA.1=0:led=0
    		Else
    			PORTA.1=1:led=1
    		EndIF
    GoTo ricevi
    Try this. It's tested on a 16F627a @4MHz using the MicroCode Studio terminal program.
    I suspect your problem may be due to data-rate errors & trying to write to EEPROM with interrupts enabled. This works perfectly at a data-rate of 19,200 @ 4MHz.
    Use a PC RS232 terminal program that will allow you to send/receive with odd or even parity & view the results on your terminal program. The PIC is setup to send & receive 9-bit.
    This will echo the received address byte back to the PC terminal software using 9-bit send & receive 9-bit with auto address detect. An LED on RB0 will toggle only when in the interrupt service routine.
    Note: If you have your PC terminal software set for EVEN parity, then the program (PIC) will only respond to 1,2,4,7 or 8 because these values will generate a logic 1 as the parity bit which the PIC *must* see in 9-bit mode.
    If you set it for ODD parity, the PIC will only respond to 3,5,6,9 or 0.
    Any value sent to the PIC that does not generate a logic 1 as the 9th parity bit will be ignored, and no interrupt will be generated.
    OERR    VAR RCSTA.1    ' (Read Only) USART over-run bit
    RCIF    VAR PIR1.5	  ' (Read Only) USART received character interrupt flag bit
    ADEN    VAR RCSTA.3    ' Alias Address enable bit (for 9-bit mode)
    X       VAR BYTE       ' GP
    PORTB.0 = 0            ' Initialize port bit
    TRISB.0 = 0            ' RB0 = LED interrupt indicator
    txsta.6=1 'TX9 : 9-bit Transmit Enable bit
    txsta.3=0 ' N/A
    txsta.0=1 'TX9D : 9th bit of transmit data. Can be parity bit.
    PIE1.3=0 ' N/A
    SPBRG = 12 ' 19,200 bps @ 4MHz 16F627a
    ON INTERRUPT GOTO IntHandler
       FOR X = 0 TO 255    ; Waste some time waiting for characters
        PAUSEUS 10
       NEXT
       GOTO Main
        DISABLE
    IntHandler:
        PORTB.0 = PORTB.0^1 ' Indicate that we are in interrupt routine
        IF RCIF THEN        ; Read characters from RCREG only when RCIF is set
          @ movf RCREG, W   ; Load RCREG into W
          @ movwf TXREG     ; Transmit back to PC
        ' Clear over-runs if present
         EndIF
        Resume
        Enable
    -Bruce
    tech at rentron.com
    Morpheus's Avatar
    Morpheus Guest
    It's not possible!
    You can't believe where was the problem!
    It was a hardware problem!!:
    I'm using a rs485 net, and there was a short-circuit on the Tx-enable pin of my rs485 converter..
    so the char I was reading was noised by strange trasmissions on the line!!! the char I were sending was right, but the received one was mixed with other stranges things..
    sorry. The program was working right.
    Thank you Bruce for your attention.
    C yA
    Simone.
  1. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 03:35
  2. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  3. USART interrupt in PIC16F877A
    By amindzo in forum General
    Last Post: - 26th August 2006, 19:51
  4. PIC Basic PRO 16F877 USART Interrupt TX
    By BigH in forum Serial
    Last Post: - 10th January 2006, 00:26
  5. USART interrupt not interrupting :-(
    By barkerben in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 14:30
