usb to serial and back on the fly with ucase$
Results 1 to 18 of 18
    Default usb to serial and back on the fly with ucase$
    Ok I was thinking of a little project to test the old grey cells and to finally how to learn how to use USB as i am planning to need it soon, and sooner jump into a big project this seems easier....
    Set usb on the pic to appear to windows as a virtual com-port
    if available, read a character, from the virtual com-port, convert it to upper case, and then output it at 9600 via the hwuart....
    and....
    if available, read a character, from the hwuart , convert it to upper case, and then output it at 9600 via the virtual com-port
    continue till the worlds end.
    Now its all simple when written down, and i can easily achieve this if it was using the hwuart and a swuart, but i am lost with the usb side.
    I think i'm in the same boat as alot of people on this, so can we do this simply, if usb is such a thing.....
    I know there are lots of easy this and that and HIDeous things around, but the keyword is simple.....
    Got a spare 18f2550 and a 4mhz crystal here i think may be just the ticket
    ok had a look at MCS and easyhid, tried to compile the output it generated, but i got an error that pbppic18.lib could not be found.
    i added a line near the top, include ''pbppic18.lib'' but now get an error a redefinition of label of [ifndef]
    never easy is it, even when its called easy.....
    Default it still hates me...
    Ok i found the easy cdcusb demo thingy....(technically minded me)
    i eventually got it all copiling without errors once i fixed the paths in the 'incs'
    but....
    now i have another issue...
    this is a segment of my test code
        portb=16+8
        portb=8+1
        USBInit
        portb=8
    It gets to ubinit with all being fine, then the lights go out, and thats the end of it.....
    if it was waiting at usbinit or stuck at it i would expect the lights to stay on...
    anyone know why that happens, windows does nothing either.
    It looks like the External USB Transceiver pins are active. (VPO VMO etc.)
    Have you changed the UCFG register?
    You should not.
    You should not.
    it has a ucfg register? i just downloaded the usbcdc demo and compiled it, when i said i fixed the incs i meant the inc issue with the 18f2550 fuses and the invalid path in one of the incs i found.
    by flashing the leds on portb etc i know i am running internally at the right speed so my clock divs are ok.
    all i have is pic on a board with leds on the ports and a usb connector, nothing fancy, was hoping to achive success with the KISS principle..
    precompiled stuff seems to work, i used this board about two years ago with the simple usb demo, but i need to make it do serial...
    I did just find another path {c:\pbp\pic¬1.47\} that i need to edit but the phone just went and i have to go drive someone shopping!
    thanks for the reply, i'll update when they stop dragging me back to the real world
    ok now i want to scream at it..........
    buffer	Var	Byte[16]
    cnt	Var	Byte
    flash var byte
    LED0	Var	PORTB.0
    LED1	Var	PORTB.1
    LED2	Var	PORTB.2
    LED3	Var	PORTB.3
    LED4	Var	PORTB.4
    CMCON = 7            ; turn off comparators
    ADCON1 = 15            ; turn off analog inputs
    define OSC 48
    trisa=0
    trisb=0
        high led0
        high led1
        high led2
        high led3
        high led4
    pause (1000)
        low led4
    pause (1000)
        low led3
    pause (1000)
        low led2
    pause (1000)
        low led1
    pause (1000)
        low led0
    pause (1000)  ; end of the pretty countdown
        portb=9
       ; usbinit
        portb=8
        pause 1000   ; never gets to here if i un-rem usbinit
        portb=16
    ; Wait for USB input
    idleloop:
    ;   USBService	' Must service USB regularly
    ;	cnt = 16	' Specify input buffer size
        if flash=0 then
    	portb=1
    	flash=1
    	portb=0
    	flash=0
    ;   USBIn 3, buffer, cnt, idleloop
    pause 1250
        goto idleloop
    with the usb bits rem'd out, the led's flash as expected, as soon as i un=rem usbinit, it hangs at usbinit
    actually, after displaying '9' on portb, it goes immeditaly to showing '1', and i mean immediate, no one second pause displaying '8'
    to get to '1' it must pass '8', but then if it got to '1', it should flash between '1' and '0'.........and it does not - ant that last pause is 125 not 1250........
    now i am confused
    I see that you changed the label Loop to IdleLoop.
    Was that because you have PBP 2.60?
    If so, you'll need to make some changes.
    USB is different now.
    ADDED: If it is 2.60 ... Check out this ...
    http://www.picbasic.co.uk/forum/show...0301#post80301
    Last edited by Darrel Taylor; - 31st October 2009 at 02:56. Reason: CDC with PBP 2.60
    no it was idleloop as down loaded from here
    http://www.melabs.com/resources/samp...pbp/usbcdc.bas
    ' USB sample program for PIC18F4550 CDC serial port emulation
    '  Compilation of this program requires that specific support files be
    '  available in the source directory.  You may also need to modify the
    '  file USBDESC.ASM so that the proper descriptor files are included. For
    '  detailed information, see the file PBP\USB18\USB.TXT.
    buffer	Var	Byte[16]
    cnt	Var	Byte
    LED	Var	PORTB.0
    Define  OSC     48
    	USBInit
    	Low LED		' LED off
    ' Wait for USB input
    idleloop:
    ' Message received
    	Toggle LED
    	buffer[0] = "H"
    	buffer[1] = "e"
    	buffer[2] = "l"
    	buffer[3] = "l"
    	buffer[4] = "o"
    	buffer[5] = " "
    	buffer[6] = "W"
    	buffer[7] = "o"
    	buffer[8] = "r"
    	buffer[9] = "l"
    	buffer[10] = "d"
    	buffer[11] = 13
    	buffer[12] = 10
    	buffer[13] = 0
    outloop:
    	USBOut 3, buffer, 14, outloop
    	Goto idleloop	' Wait for next buffer
    using 2.47
    I changed the chip type to 2550 in MCS, copied the usb support files into my pbp directory, and compiled..
    hey prestnot......
    so added a few led statements and lost more hair, and i'm still here, its not going to win the war, battles its winning on but i'm not keeping count....
    is there any fuses that may stop usb working ?
    maybe i have something wrong in that area because the basic programs so short theres not a lot of possibility of error, so thinking its something thats not to be seen going on, or not going on.
    Quote Originally Posted by f_lez
    Did you read the USB.TXT file?
    They don't go in the PBP folder. They go in your project's folder.
    Now you've messed up the .bas files for all the USB chips, and will have to restore them from the CD or a backup.
    Did you modify the USBDESC.ASM file to point to the CDC descriptors?
    Do you have a .22uF or higher capacitor on VUSB?
    Are your configs set for a 4Mhz crystal, with USB regulator enabled?
            __CONFIG    _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
    And restore the program back to what it was originally (download it again).
    It won't work the way you've modified it.
    going to do a full wipe and start afresh.
    I take it i can use latest mpasm with me old 2.46, or should i get old mpasm? i'll go with the latest one for now.
    hell i even spent most of yesterday trying 'other products' but by last night i gave up, too many buttons and options and built in this and that i could not see what it was doing!
    Ok, I'm going slowly and step by step now and leaving my educated guesses where they belong.....
    pbp2.46 from cd to c:\pbp
    pbp2.46a patch from melabs website link
    mpasm 5.20 from melabs website link, to c:\mpasm
    MCS installed and pointed to pbp and mpasm
    New project director c:\pic2009\usbtest091101\
    All files from c:\pbp\USB18\ to project directory
    edit usbdsc to:
    ; This file contains an include for the application specific
    ; USB descriptors.  Include only ONE of the following or add
    ; your own for your own project.
    ;	include "MOUSDESC.ASM"		; USB descriptors for mouse demo
    ;	include "JADESC.ASM"		; USB descriptors for Jan Axelson's demo
    	include "CDCDESC.ASM"		; USB descriptors for CDC demo
    @this point i get the config has been depreciated but with the recession what hasnt.....
    I'l go burn this and see what happens
    You can only use the newest MPASM with PBP v 2.60. For any earlier version, MPASM 8.15a (or earlier) is the way to go. http://melabs.com/downloads/mplab_v815a.zip
    http://www.scalerobotics.com
    Thanks, but i'm on 246, but it seems ok with mpasm5.2
    Fuses, mine are a little different , i'm on 20mhz so i have these in the inc
            __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    At the top of the program, right after define OSC etc i put a high led pause 1000 low led and led lights for 1 second so looks ok
    On the dev board/programmer it lights 4 seconds, but that does have a 4mhz, i should change devboard/prototype to same crystal really
    not detected by windows, back on dev board if i switch portC led's on i get a good light on RC3 and a dimmer one on RC5, if i poke a shaky finger at rc4, rc5 flickers, so looks like its running.
    ...oh hang on BRB, theres a compiler error about overwriting previous contents, could have been there a while as its down bottom of screen and you have to scroll past the depreciated warnings
    Back, set config1 more than once...
    fixed, no improvement
    Default Working!
    Ok this has been a voyage of discovery, DT has once again proved he knows what he's on about with these black squiggly caterpillar shaped things and is a patient man, although he could have been throwing things at the screen reading my meanderings i dont know..
    Anyhow, I thank him, and respect his advice, and by following it, I have won the war.
    So, I now pass on my words of wisdom learned form this, and i also offer my hex for others following the path.
    1) if nothing seems to be making sense - reinstall PBP and MPASM and your text/source editor IE MCS
    2) RT*F*M ! TWICE - I copied files into the wrong places and ruined it all, had to go back to step 1, you may too, we all do from time to time, no matter how much you tell yourself you dont need to, for the sake of 15mins, DO IT
    3) Check your HW - the USB bus is a funny old thing, find one of the usual example diagrams, and wire it that way, dont add anything, dont be a genius and take something off, do it as it shows, exactly as it shows, the three important connections are D+,D- and the VUSB capacitor, do not be having bright ideas, just build as it is in all the diagrams, its the same in them all for a reason, that way works.
    4) Use a standard crystal size like 4mhz or 20mhz if possible, reason being you may be lucky and find someone has posted some pre-compiled code for your chip, then you can just burn that to test your hardware, thats one part of the puzzle completed, if it does not work then, fix your hardware, if it works and your code does not, fix your code, you win half the battle if you can find some code to help you
    5) Dont give up, dont expect immediate help, it can take a few days for someone to remember something that may help you, just wait patiently and do something else in the mean time
    I hope my blundering efforts to get USB working give you hope, I managed it, I'm not the best at this by a long way, I got my help and I'm a happy bunny, now I'm going to try and help back, by posting some simple working hex so if you are having problems, you can test your hardware before blaming your software....
    Heres another good place to start
    http://www.picbasic.co.uk/forum/showthread.php?t=5806
    Pic 18f2550 USB-CDC 4Mhz
    When burned to pic and built up on a board fit led to portb.0 it will flash twice and then init usb connection
    LED should be on for one second and off one second, if not check your crystal is right and your programmer has not changed any of the fuse settings to a different pll/cpu div
    This is for a 4mhz crystal to the pll (pll/1) and cpudiv=1(pll/2) which is 48mhz clocking
    :020000040000FA
    :1000000022EF00F0036A026EFF0E0226D8A003263C
    :10001000D8A01FEF00F0030E016EE70E02D8F4D750
    :10002000016AFD0F006EFF0E00D001D00026040013
    :1000300000D000D0D8A00126D8A01200F7D7000128
    :10004000040012000CEF04F0120C010C100C010C57
    :10005000020C000C000C080CD80C040C0A0C000C50
    :10006000000C000C010C020C030C010C7000700061
    :10007000090C020C430C000C020C010C020C800C4D
    :10008000500C090C040C000C000C010C020C020CAE
    :10009000010C000C050C240C000C100C010C040CC1
    :1000A000240C020C020C050C240C060C000C010C98
    :1000B000050C240C010C000C010C070C050C820C27
    :1000C000030C080C000C020C090C040C010C000CB5
    :1000D000020C0A0C000C000C000C070C050C030CA5
    :1000E000020C400C000C000C070C050C830C020CDD
    :1000F000400C000C000C0001080130016801840173
    :10010000040C030C090C040C140C030C4D0C000C17
    :10011000690C000C630C000C720C000C6F0C000CD2
    :10012000630C000C680C000C690C000C700C000CCB
    :100130001C0C030C500C000C490C000C430C000C64
    :10014000310C000C380C000C200C000C550C000C71
    :10015000530C000C420C000C200C000C430C000C47
    :10016000440C000C430C000C0E0C030C560C000C41
    :10017000310C000C2E0C000C310C000C460C000C49
    :10018000530C000C0A0C030C430C000C660C000C06
    :10019000670C000C310C000C04012E51600B0008A0
    :1001A0003EE1050E2F6303D0040E2A6F36D0060EF3
    :1001B0002F6301D035D0080E2F6309D02B0E226F8C
    :1001C000040E236F010E286F296B2D9326D0090E84
    :1001D0002F6301D06AD0000E2F6301D07ED0010EB4
    :1001E0002F6301D09FD0030E2F6301D09BD00A0E46
    :1001F0002F630BD02C0E226F040E236F3251222757
    :10020000010E286F296B2D9308D00B0E2F6312005F
    :1002100024EE2CF0325130C4DBFF010E276F1200A8
    :10022000800E2E631200010E31630FD0480E226F34
    :10023000000E236F22C4F6FF23C4F7FFF86A0800FC
    :10024000F5CF28F4296B2D83E8D7020E316312D045
    :10025000700E226F000E236F740EF66E000EF76E96
    :10026000F86A0900F5CF28F409000900F5CF29F450
    :100270002D83D3D7030E31631200F86AF76A304535
    :10028000F60FF66E000EF7220900F5CF22F40800F3
    :10029000F5CF23F422C4F6FF23C4F7FFF86A080061
    :1002A000F5CF28F4296B2D83B8D7010E276F2FEED9
    :1002B00071F00F0EDE6AE82EFDD724EE2CF0010E51
    :1002C000DE6AE82EFDD730512B6F03E1050E2A6F51
    :1002D0001200060E2A6F08DA1200366B376B2E51A9
    :1002E0001F0B000803E12DB136830ED02E511F0BDA
    :1002F000010801E109D02E511F0B020807E134D893
    :10030000DF50040B01E03681010E276F010E2763D9
    :100310001200360E226F040E236F020E286F296B17
    :100320002D931200010E306309D02E511F0B0008CF
    :1003300005E12D81030E2F632D916FD7000E3063E1
    :1003400012002E511F0B0208FBE132510F0BF8E097
    :100350000BD8030E2F6303D0840EDF6E5ED7000E22
    :1003600032AF880EDF6E59D724EE00F032453235B9
    :10037000E846E846D9261200000E6C6205D000510E
    :100380003C0B340805E010D0040E6C62120015D04E
    :10039000000E266F000E276F286B296BFDDE000E06
    :1003A000276379D045D977D0020E2663AFD057D8CE
    :1003B000C80E00BD880E006F1200040E2A6306D01E
    :1003C00030516E6E050ED8B4030E2A6F010E2663EF
    :1003D0009DD005D8C80E04BD880E046F12002851A8
    :1003E000206F2951216F000804E307E12851080814
    :1003F00004E2080E206F000E216F2051056F285F68
    :100400002151295B0451FC0B2111046F24EE36F0BD
    :10041000215102E1205122E02DA312D022C4F6FF87
    :1004200023C4F7FFF86A0900F5CFDEFF09002007B3
    :10043000FAE12107F8E2F6CF22F4F7CF23F4120015
    :1004400022C4E1FF23C4E2FFE6CFDEFF2007FCE188
    :100450002107FAE2E1CF22F4E2CF23F412000151A6
    :10046000206F28270051030B216F292314EE36F04B
    :1004700024C4D9FF25C4DAFF215102E120510AE04A
    :10048000E6CFDEFF2007FCE12107FAE2D9CF24F412
    :10049000DACF25F41200000E27630AD0080E016F90
    :1004A0002E0E026F040E036F840E006F046F2CD0AB
    :1004B0002EAF1DD02951355D04E307E12851345D8D
    :1004C00004E234C428F435C429F489DF010E266F10
    :1004D000080E016F2E0E026F040E036F800E006F68
    :1004E000360E066F040E076FC80E046F0DD0020E95
    :1004F000266F056BC80E046F080E016F360E026F73
    :10050000040E036FC80E006F6D981200000E266F68
    :10051000080E016F2E0E026F040E036F880E006F1F
    :10052000000E046F12000401140E6F6E000E2A6F8D
    :100530002D6B2B6BD9D8120004016DA60CD8010EBF
    :100540002A6312006DBA1200686A696A6980698854
    :10055000020E2A6F12006D6A696A6D86010E2A6F9B
    :10056000120004016D6A696A000E2A6F120004010C
    :10057000000E2A5D23E068A402D069B424D86DB2CD
    :10058000120068A002D069B039D868A802D069B852
    :1005900016D868AC02D069BC28D868AA02D069BA5B
    :1005A00026D868A202D069B227D8030E2A5D06E3D6
    :1005B00068A604D069A602D0DFDE689612006984BE
    :1005C00068986D8212006D9269946894120004011B
    :1005D0002DA11200F8DF6D84100EDA6ED96AD92EC3
    :1005E000FED7DA2EFCD76D941200689C120070B012
    :1005F0008DDF7090689A1200689212006A6A686AC9
    :100600009F0E6B6E7B0E696E6E6A2FEE71F00F0E91
    :10061000DE6AE82EFDD7160E706E68B6689668B66C
    :10062000FDD76D9873DF2D912B6B030E2A6F12008F
    :1006300004012E511F0B010809E12E51600B200807
    :1006400005E1000E325D03E0010E32631200000E80
    :100650002F6309D0460E226F040E236F2D93080ED0
    :10066000286F296B3ED0010E2F6305D0460E246FF4
    :10067000040E256F36D0020E2F6301D01200030E38
    :100680002F6301D01200040E2F6301D01200200E40
    :100690002F6305D03E0E246F040E256F22D0210E4D
    :1006A0002F6314D0000E3E6FC20E3F6F010E406FDD
    :1006B000416B426B436B080E446F3E0E226F040E7B
    :1006C000236F2D93070E286F296B0BD0220E2F63FB
    :1006D00003D030C445F405D0230E2F6301D012009F
    :1006E0001200030E276F1200020EE96E14EE4EF098
    :1006F000080E0CD8030EE96E14EE57F0400E1CD80D
    :10070000030EE96E14EE98F0400E00D0E66E2FEE68
    :1007100070F0E950D9261A0EDF12E944E846E8469F
    :1007200004EE04F0E926020EE1CFEBFF030EE2CF68
    :10073000EBFF400EEF6E1200E66E2FEE70F0E95008
    :10074000D9261C0EDF12E944E846E84604EE00F024
    :10075000E926020EE1CFEBFF030EE2CFEBFFE550FF
    :10076000E92AE7CFEDFF880EEF6E1200006E04015C
    :10077000060E2A5D000ED89009E1E944E846E846F5
    :1007800004EE04F0E926000ED890EFBE1200020E2F
    :10079000EBCFD9FF030EEBCFDAFFFF0EDB5000608B
    :1007A000006EE92A0050ED6E04E0E6CFDEFFE82E91
    :1007B000FCD7400EEF16EF7C880EEF120050D88069
    :1007C0001200006E0401060E2A5D000ED89009E1A9
    :1007D000E944E846E84604EE00F0E926000ED89029
    :1007E000EFBE1200020EEBCFD9FF030EEBCFDAFF04
    :1007F000EC500060006EFF0EDB50ED6E005004E028
    :10080000DECFE6FFE82EFCD7400EEF16EF7C880E19
    :10081000EF120050D880120081809390030E036E77
    :10082000E80E03EC00F081909390030E036EE80E47
    :1008300003EC00F081809390030E036EE80E03EC4E
    :1008400000F071DE1FEC00F081909390010E036EBA
    :10085000F40E03EC00F0818093906EDE88DE1FECD6
    :1008600000F0100E1A6E030EE96E10EE1BF01A5017
    :10087000A8DF1FEC00F01A6ED8A0EFD7817093901C
    :10088000480E1B6E650E1C6E6C0E1D6E6C0E1E6E81
    :100890006F0E1F6E200E206E570E216E6F0E226E91
    :1008A000720E236E6C0E246E640E256E0D0E266E77
    :1008B0000A0E276E286A40DE5ADE1FEC00F0030E97
    :1008C000E96E10EE1BF00E0E51DF1FEC00F0D8A009
    :1008D000F2D7C3D7FFFFFFFFFFFFFFFFFFFFFFFFC1
    :1008E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
    :08000000FFFFFFFFFFFFFFFF00
    :020000040030CA
    :0E00000020CF3F0F0085A1000FC00FE00F4082
    :0200000400F00A
    :10000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00
    :10001000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
    :10002000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0
    :10003000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0
    :10004000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
    :10005000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0
    :10006000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
    :10007000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90
    :10008000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80
    :10009000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70
    :1000A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60
    :1000B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
    :1000C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40
    :1000D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30
    :1000E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20
    :1000F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10
    :00000001FF
    Pic 18f2550 USB-CDC 16Mhz
    This is for a 16mhz crystal to the pll (pll/1) and cpudiv=1(pll/2) which is 48mhz clocking
    :020000040000FA
    :1008F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08
    :10090000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7
    :107FC000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1
    :107FD000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1
    :107FE000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1
    :107FF000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
    :020000040020DA
    :020000040030CA
    :0E00000023CF3F0F0085A1000FC00FE00F407F
    :0200000400F00A
    :00000001FF
    Pic 18f2550 USB-CDC 20Mhz
    This is for a 20mhz crystal to the pll (pll/1) and cpudiv=1(pll/2) which is 48mhz clocking
    :020000040000FA
    :020000040020DA
    :020000040030CA
    :0E00000024CF3F0F0085A1000FC00FE00F407E
    :0200000400F00A
    :00000001FF
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Raw serial data sniffer? By USB??
    By kevj in forum General
    Last Post: - 5th July 2008, 14:34
  3. Advice please - Warning message
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2007, 13:20
