usb to serial and back on the fly with ucase$
Results 1 to 18 of 18
Threaded View
  1. #14
    Thanks, but i'm on 246, but it seems ok with mpasm5.2
    Fuses, mine are a little different , i'm on 20mhz so i have these in the inc
            __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
            __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
    At the top of the program, right after define OSC etc i put a high led pause 1000 low led and led lights for 1 second so looks ok
    On the dev board/programmer it lights 4 seconds, but that does have a 4mhz, i should change devboard/prototype to same crystal really
    not detected by windows, back on dev board if i switch portC led's on i get a good light on RC3 and a dimmer one on RC5, if i poke a shaky finger at rc4, rc5 flickers, so looks like its running.
    ...oh hang on BRB, theres a compiler error about overwriting previous contents, could have been there a while as its down bottom of screen and you have to scroll past the depreciated warnings
    Back, set config1 more than once...
    fixed, no improvement
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. Raw serial data sniffer? By USB??
    By kevj in forum General
    Last Post: - 5th July 2008, 15:34
  3. Advice please - Warning message
    Last Post: - 23rd January 2007, 14:20
