Counter not counting !!!
Results 1 to 25 of 25
    Sep 2006
    Default Counter not counting !!!
    Hello,
    I made a small disk counter with (wheel encoder with 2 part black and 2 part white) about 2 inches in diameter. I use a light to voltage sensor. It is working pretty well at low speed, but when I flick the disk, o Maybe a few turns per seconds the counter only counts one out of the 5 turns it made. My guess is that the clocking should be made higher.. any ideas?, The whole circuit is already soldered, I hope i do not need to get it in a 20Mhz crystal.
    here is the code:
    ' Internal Oscillation program
    ' A/D testing -RA.1
    ' LCD
    '// Define section //
    INCLUDE "modedefs.bas" 'Includes supoprt for PicBasic language
    @ DEVICE pic16F88, INTRC_OSC, CCPMX_ON, MCLR_ON
    OSCCON=$60 ' use internal 4MHZ osc
    CMCON = 7 ' Turn OFF the comparators so pins can be used as digital I/O-pins
    '// LCD configuration //
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    '// PIN configuration //
    TRISA = %11100111 ' Set PORTA to all input
    TRISB = %00001100 ' Set PORTB to all output
    PortA = 0
    '// Variable Declaration and initialization //
    Output_Pot var byte
    OldOutput_Pot var byte
    Revolution var word
    counter var byte
    revolution = 0
    Output_Pot = 0
    OldOutput_Pot = 0
    counter = 0
    OldOutput_Pot = PortB.3
    Mainloop:
    'Calculate the distance
    if OldOutput_Pot == Output_Pot then
    goto Mainloop
    if OldOutput_Pot != Output_Pot then
    counter = counter +1 'If oldOutput_pot is different then Output_pot
    OldOutput_Pot = Output_Pot
    if counter =4 then
    Revolution = Revolution + 1
    counter =0
    lcdout $FE,1, "Counter:",dec counter
    lcdout $FE,$C0, "Revolution:",dec Revolution
    pause 150
    GOTO Mainloop
    Bombay, India
    Time to consider using interrupts for this. Increment within the interrupt. Keep it small and fast!! I don't recall if the 88 has interrupts on portB.3
    Sep 2006
    interrupt ... ok Guess I have to read up now.
    I would suspect the "light-to-voltage sensor". Most of these have response times in the millisecond range, maybe too slow.
    Sep 2006
    I am not sure how interrupt can help in this case.
    At slow speed the counter works, but at higher speeds it does not pick half the time or more.
    I reduced the pause time to 20 after the LCDout, that did not help.
    K
    Hi lerameur,
    I would use a photo transistor and not a photocell, a Crystal or resonator running at 20 mhz rather than intosc @ 4mhz. those things might speed things up a bit. You might use interrupts to capture counts and display on an as time permits basis instead of watching every count.
    Sep 2006
    I am using this little baby for a sensor
    http://www.taosinc.com/productdetail.aspx?product=63
    I think i will user TMR0 in my program
    K
    I was thinking . . . make a subroutine called display and do this:
    gosub display
    then do your lcd routines in there, it would display any time the counter stops incrementing.
    Bombay, India
    Well, the reason for suggesting an interrupt is simple. When you poll, you spend a finite time in checking the state of the input. If you miss this(fast revolutions), you will miss counts. However, if you use interrupts, you can be sure to catch a significantly higher number of pulses than you could using the poll technique. example - you may be able to read upto 20pulses per second using the poll techniqe, but upto 200 pulses per second or even more using interrupts.
    Simple analogy to understand the difference between interrupts and polling.
    Think of yourself seated at the PC doing some work. The time you take to respond to a person at the door is your 'poll time' and depends on what you are doing at the moment and how soon it will finish. This would be similar to checking every now and then to see if there is someone at the door.
    On the contrary, if the person rings a doorbell (interrupts). You know that the door needs to be opened because of this signal. The way the processor handles it is to finish the current 'instruction' that it is executing and respond to the bell. This is much much faster than the earlier technique of checking the door now and then.
    Please don't mind the over-simplification. It might help someone else understand.
    I also second the idea that the opto interrupter may not be fast enough. But, from my experience, they work well into the KHz range.
    I suggest your Main loop should just display the counts and the interrupt routine should just count.
    Sep 2006
    Ok I added an interrupt and wrote the program from what you said. Althouth I get zero on the LCD, seems that the interrupt is not working, can you help me debug it? Do I need to initialize some parameter . I am using the pic16f88
    Ken
    ' LCD
    ' Main loop display the counts and the interrupt routine counts
    '// Interrupt section //
    OPTION_REG = %00111000
    'Transition on TOCKI (RA4),
    'Increment on falling edge
    'Prescalar assigned to WDT for a 1:1 TMR0 ratio.
    INTCON.2 = 0 ' Clear Timer0 int flag
    INTCON.5 = 1 ' Enable Timer0 int
    TMR0 = $FF ' Set TMR0 to 255. So one more tick and TMROIF will be set.
    TRISA = %11110111 ' Set PORTA to all input
    ' Set PORTA.4 (TOCKI) to input for timer0
    TRISB = %00001111 ' Set PORTB to all output
    PortA = 0
    Revolution var word
    Counter var word
    oldCounter var word
    feet var word
    feet_left var word
    feet_right var word
    revolution = 0
    Counter = 0
    feet = 0
    PortB.2 = 1 'Put to 5v via a resistor and a pushbutton to ground for reset
    ON INTERRUPT GOTO LapCount
    Mainloop:
    if PortB.2 = 0 then
    goto Reset_variables
    lcdout $FE,1, "Cter:",dec Counter, " Rev:",dec Revolution
    lcdout $FE,$C0, "Feet:",dec feet/12, ".", dec2 feet//12 'This will save feet, and the // will print the decimal to two decimal point
    pause 20
    GOTO Mainloop
    Reset_variables:
    revolution = 0
    Counter = 0
    feet= 0
    lcdout $FE,1, "Counter:",dec Counter , " Rev:",dec Revolution
    pause 20
    GOTO Mainloop
    disable
    LapCount:
    If INTCON.2 = 1 then
    Counter = Counter + 1
    toggle PORTB.3
    TMR0 = $FF ' Indicate we're in interrupt handler
    INTCON.2 = 0 ' Clear TMR0 Interrupt Flag (Bit 2)
    if Counter =4 then
    Counter =0
    feet_left = Revolution *3
    feet_right = Revolution *25
    feet_right = feet_right / 100
    feet= feet_left +feet_right
    Resume
    Enable
    Sep 2006
    by the way I connected the sensor to portA.4
    ken
    Quote Originally Posted by lerameur View Post
    Ken
    ' LCD
    PortA = 0
    Revolution var word
    Counter var word
    oldCounter var word
    feet var word
    feet_left var word
    feet_right var word
    revolution = 0
    Counter = 0
    feet = 0
    Mainloop:
    if PortB.2 = 0 then
    pause 20
    GOTO Mainloop
    Reset_variables:
    revolution = 0
    Counter = 0
    feet= 0
    pause 20
    GOTO Mainloop
    disable
    LapCount:
    toggle PORTB.3
    if Counter =4 then
    Counter =0
    Resume
    Enable
    <font color=red> PortA.3 as output</font color>
    <font color=red> PortB.0:3 as inputs</font color>
    PortA = 0
    For starters, check this to see if it is what you really want.
    PortA.4 is Schmitt Trigger input so a pulldown resistor as shown in the opto's datasheet will be a necessity, it says it outputs min 3.0v so it should swing the S T input OK. The 16F88 has a ton of analog you need to attend to if you want to use it, I am not seeing any code to do that.
    Sep 2006
    the hardware seems good, like I said it works at slow speed. In my case I have to use port RA4 right? to get the timer0 from my program.
    I looked through the datasheet and nowhere there is mention on how to disable the schmitt trigger.
    ken
    Lightbulb
    Hi, Ken
    IF you want your Thing to work properly ...
    You HAVE to use QUICK Interrupts and not " On Interrupt" ... especially if using a LCD.
    So, Have a look to asm interrupts or Darrel Instant Interrupts ...
    Why not just let hardware handle most all of this for you?
    ' include your hardware/config stuff here
    Revs VAR BYTE ' holds up to 255 revolutions
    ANSEL = 0     ' disable A/D so RA4 is digital
    CMCON = 7     ' disable comparators
    OPTION_REG = %00110001 ' RA4 = count input
    ' inc count every 4th falling edge with 1:4 prescale
    ' assigned to TMR0
    Mainloop:
        TMR0 = 0      ' clear count before pause
        PAUSE 20      ' Adjust this to set how long it counts revolutions here
        Revs = TMR0   ' TMR0 counts 1 rev for every 4 pulses
        LCDOUT $FE,1,"Revs: ",DEC Revs
        ' do other stuff here, then return to get more counts
        GOTO Mainloop
    This will be a LOT faster than interrupting on every single pulse, and counting
    in software. You should be able to give the wheel a pretty good spin without
    missing anything.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2006
    HI, I am not able to make this code work, always leaves me with ORevs = 1 on the LCD.
    I also change the oscillation to 20 Mhz but did not see any difference.
    ken
    ' LCD
    @ DEVICE pic16F88, INTRC_OSC, MCLR_ON
    ANSEL = 0 : ADCON1 = 7
    CCP1CON = 0 'CCP1 module off
    TRISA = %11111111 ' Set PORTA.4 (TOCKI) to input for timer0
    PortA = 0
    Revs var word
    ORevs var word
    ' assigned to TMR0
    Mainloop:
    ORevs = Revs +1
    LCDOUT $FE,1,"ORevs: ",DEC ORevs
    GOTO Mainloop
    As Joe already mentioned earlier, RA4 T0CKI is a Schmitt Trigger input. If your sensor doesn't output a minimum voltage of 0.8 * VDD for logic 1 and 0.2 * VDD or less for logic 0, then the Schmitt Trigger input isn't seeing the correct logic levels, and TMR0 isn't counting your pulses.
    Here's a quick little test program to show how it works when RA4/T0CKI is connected to an I/O-pin to increment the counter.
    @ DEVICE pic16F88, INTRC_OSC, CCPMX_ON, MCLR_OFF
    DEFINE HSER_BAUD 2400
    Loops VAR BYTE
    Revs var BYTE
    TRISA.4=1  ' RA4/T0CKI = input (Timer0 clock input)
    PORTB.5=1  ' USART TX pin idles high
    PORTB.0=1  ' clock output pin to RA4 starts high
    TRISB.0=0  ' clock out pin to RA4/T0CKI = output
    TRISB.5=0  ' USART TX = output
    OPTION_REG = %10110001 ' clk on RA4/T0CKI, falling edge, 1:4 prescale
    Mainloop:
        TMR0 = 0      ' clear count before each pass
        ' output 8 clocks on RB0 to RA4/T0CKI
        FOR Loops = 0 TO 7
          PORTB.0=1   ' RB0 connects to RA4/T0CKI
          PAUSE 5
          PORTB.0=0   ' counter increments on falling edge
          PAUSE 5
        NEXT Loops
        Revs = TMR0   ' get TMR0 count
        IF OPTION_REG.0 THEN
           HSEROUT ["Counts at 1:4 prescale: ",dec Revs,13,10]
           HSEROUT ["Counts at 1:2 prescale: ",dec Revs,13,10]
        OPTION_REG.0 = OPTION_REG.0 ^ 1 ' toggle 1:4 or 1:2 prescale
        GOTO Mainloop
    It works great, but only as long as the input signal meets the threshold levels the Schmitt Trigger input buffer on RA4/T0CKI expects.
    -Bruce
    tech at rentron.com
    Loops VAR BYTE
    Revs var BYTE
    Mainloop:
        FOR Loops = 0 TO 7
          PAUSE 5
          PAUSE 5
        NEXT Loops
        GOTO Mainloop
    I learned something again! I thought Schmitt trigger would switch at 3v, so 80 percent huh? I'm going to write that down. Thanks Bruce !
    Sep 2006
    Hi
    well I am only getting about 3volt, so 0.8 * 5v = 4v, one volt away from triggering. I will a simple amplifier or inverter to the output of my sensor and feed that to the chip
    ken
    Sep 2006
    I think I am getting there but just not quite.
    your program works with the loop for incrementing. I removed the loop , because I have a sensor output, The output is going through an inverter, so now I get either 0 or 5v going into RA4.
    What I now see on the LCD is the incrementation going up high without any look at the input. it goes up to a 1000 in about 3 seconds with the sensor laying there not moving:
    Here is the code I have, mainly Bruce,s code with the addition of the LCD and external oscillation.
    @ DEVICE pic16F88, CCPMX_ON, MCLR_OFF
    DEFINE OSC 20 'use external 20mhz crystal
    Revs var BYTE
    ORevs var word
    Counter var word
    Counter =0
    Mainloop:
    'instead, input from sensor
    Counter = Revs + 1
    LCDOUT $FE,1,"Counter1: ", DEC Counter
    lcdout $FE,$C0, "Counter2: ", DEC Counter
    GOTO Mainloop
    Sep 2006
    also, I used your program andn it seemed to work but I realized that even if I remove the Loop: (or simply remove the connection between RA4 and RB3)
    FOR Loops = 0 TO 7
    PORTB.3=1 ' RB0 connects to RA4/T0CKI
    PAUSE 5
    PORTB.3=0 ' counter increments on falling edge
    PAUSE 5
    NEXT Loops
    the incrementation stays the same change, so I guess there si not effect on TMR0.
    K
    Try this;
    Mainloop:
    PAUSE 5000 ' give it some time to count pulses
    LCDOUT $FE,$C0, "Revs: ", DEC Revs
    GOTO Mainloop
    Counter of course is always going to change every 5 seconds or so, but Revs shouldn't until you have pulses in on RA4.
    Timer0 will automatically count pulses. You don't need to check any regs, bits, etc, just read it & clear it as required.
    -Bruce
    tech at rentron.com
    Sep 2006
    I did output the Revs and it increment without any input:
    not as fast, takes about 2 seconds to get to ten.
    The odd thing is that it increment without changes to RA4.
    I am going to try your code you posted and be back later
    thanks for your time
    Mainloop:
    Counter = Revs + 1
    LCDOUT $FE,1,"Revs: ", DEC Revs
    GOTO Mainloop
    Sep 2006
    Hi again
    I set my function generator to 100Hz and the Revs outputs 127, when I set it to 1000Hz, I get Revs 225 on my LCD.
    I get a specific number to from different frequency input.
    Ken
    That's a good sign. Higher frequency should = a higher count in a given time period.
    FYI: You really don't need to keep flipping OPTION_REG.0. That was just a part of my
    previous example to show the count difference with different prescaler values. I would
    leve it set at one prescale if you want valid counts.
    -Bruce
    tech at rentron.com
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Replies: 42
    Last Post: - 14th January 2008, 12:38
  3. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 06:02
  4. Replies: 4
    Last Post: - 18th June 2007, 14:38
  5. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
