Reading Array values into variables - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 6 to 10 of 20
  1. #6
    >>4 => shift byte 4 position to the right. so you keep only the 4 high bits
    & $F => Bitwise and with hex F. so you keep only the 4 low bits
    everything is in the PBP manual section 4.17
  2. #7
    It's no more difficult than copying data from a single variable to another.
    X VAR BYTE
    Y VAR BYTE
    X = 3
    Y = X
    You can state X = SSMAX(23), Y = SSMAX(34), etc,,.
    Since the resulting value will be a word, then use something like this;
    SSMAX(23) contains 83h
    SSMAX(34) contains 03h
    Result VAR WORD
    Result.LowByte = SSMAX(23) ' Place 83h into lowbyte
    Result.HighByte = SSMAX(34) ' Place 03h into highbyte
    HSEROUT [DEC Result] ' Print decimal value of 0383h = 899
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  3. #8
    Feb 2005
    Bellevue
    Red face Array values into Variables - into ONE variable..
    Seems like I should be able to figure this out, but I can't ...
    I have an array that contains 24 bits which equate to an altitude in tenths of meters.
    alt[1]
    alt[2]
    alt[3]
    I need to 1) display this, and 2) convert from meters to feet, so I need to stuff all these into a single variable which represents actual meters as opposed to tenths of meters, then convert to feet....
    Any ideas out there? They way I am doing it now is not working. I am just reading these into alt1, alt2, alt2, and showing them as #alt1, #alt2, #alt3... I get 13130 which may be 131.30 meters,(which would be about right) but I am not sure. I am also not sure how to make this a single variable ..
    Thanks !
    Tom
  4. #9
    Red face
    I have no answer, but I do see an immediate problem.
    A byte contains 8 bits, a word contains 2 bytes; that's a total of 16 bits.
    There is a way to do 32 bit math, I saw a section in the manual. You work with 2 separate words or something, I didn't pay much attention.
  5. #10
    Page 33, 4.17.1 - Multiplication.
    Using * and **, / and //.
    Good luck!
  1. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 05:46
  2. Array values changing
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 00:13
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  4. Seeting array variables in For-Next loop
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 08:01
  5. Putting values into an array
    By Vince in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2003, 08:22
