Reading Array values into variables
Results 1 to 20 of 20
    >>4 => shift byte 4 position to the right. so you keep only the 4 high bits
    & $F => Bitwise and with hex F. so you keep only the 4 low bits
    everything is in the PBP manual section 4.17
    It's no more difficult than copying data from a single variable to another.
    X VAR BYTE
    Y VAR BYTE
    X = 3
    Y = X
    You can state X = SSMAX(23), Y = SSMAX(34), etc,,.
    Since the resulting value will be a word, then use something like this;
    SSMAX(23) contains 83h
    SSMAX(34) contains 03h
    Result VAR WORD
    Result.LowByte = SSMAX(23) ' Place 83h into lowbyte
    Result.HighByte = SSMAX(34) ' Place 03h into highbyte
    HSEROUT [DEC Result] ' Print decimal value of 0383h = 899
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Bellevue
    Red face Array values into Variables - into ONE variable..
    Seems like I should be able to figure this out, but I can't ...
    I have an array that contains 24 bits which equate to an altitude in tenths of meters.
    alt[1]
    alt[2]
    alt[3]
    I need to 1) display this, and 2) convert from meters to feet, so I need to stuff all these into a single variable which represents actual meters as opposed to tenths of meters, then convert to feet....
    Any ideas out there? They way I am doing it now is not working. I am just reading these into alt1, alt2, alt2, and showing them as #alt1, #alt2, #alt3... I get 13130 which may be 131.30 meters,(which would be about right) but I am not sure. I am also not sure how to make this a single variable ..
    Thanks !
    Tom
    Red face
    I have no answer, but I do see an immediate problem.
    A byte contains 8 bits, a word contains 2 bytes; that's a total of 16 bits.
    There is a way to do 32 bit math, I saw a section in the manual. You work with 2 separate words or something, I didn't pay much attention.
    Page 33, 4.17.1 - Multiplication.
    Using * and **, / and //.
    Good luck!
    Feb 2005
    Bellevue
    Question
    Exactly the problem.. I have 3 bytes that need to be put into one variable.. this is a 24 bit container that relates a number - the altitude in tenths of meters..
    How to get this into ONE variable I can work with is the first issue..
    Tom
    Wink
    Hi, Tom
    Let's have another view of the problem ...
    You get an altitude measurement, ...but what is your sensor ??? and mostly what is its precision ???
    I do not know lots of altitude sensors seriously able to give 1 cm on a hundred meters ... 1/10 000 precision, you sure ??? ... !!!
    May be a little look here could reduce your number sizes ...and simplify you work.
    24 and 32 bits arithmetics can be downloded from Melabs site ... if you really want to keep "ghost" centimeters !!!
  1. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  2. Array values changing
    By MyBuddy in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 23:13
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 08:02
  4. Seeting array variables in For-Next loop
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 07:01
  5. Putting values into an array
    By Vince in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2003, 07:22
