I2c, srf02, 16f688 -> ultrasonic rangefinder
Results 1 to 10 of 10
    May 2008
    Italy
    Default Re: I2c, srf02, 16f688 -> ultrasonic rangefinder
    Code seems OK, perhaps too short the delay between the write I2C command and the read
    Did you place the pullup resistors on the SDA and SCL lines?
    Cheers
    Al.
    Omaha, Nebraska USA
    Thanks, Al.
    Quote Originally Posted by aratti View Post
    Code seems OK, perhaps too short the delay between the write I2C command and the read.
    It's the same delay used by jellis00, but I think he was running 18F devices and I don't know at what speed. (Or if that would make a difference.)
    Yes; per the SRF02 specifications recommendation, I used 1.8K (see the schematic).
    Russ
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    May 2008
    Italy
    Russ, I think your problem is in the this line of code:
    SCL VAR PORTA.4 ' Serial clockS
    PortA.4 is an open collector pin and I think not suitable for I2C comm.
    Try to change pin.
    Cheers
    Al.
