I am not sure... As I said... my english is not really good :P But if somebody can move it for me.. please![]()
Your lines look to be an uncontrolled mix of Basic and C languages ...
So, it will be rather difficult to help you ...
BTW "Jeroen" ... that reminds me something...
what's your mother language ???
I'd bet Dutch ...
I will explain what I am trying to do... maybe it helps... in bad english, lol
I've got 2 components, a DS1820 and a simple LED, both on other ports.
When the DS1820 gets on 21,2celcius for example, the LED must blink, on 21,2+ the LED stays on, on 21,2- the LED turns off. The code I've got to control the DS1820 is:
[edit]Code:Above clear: SYMBOL Convert = $44 SYMBOL RdScratchPad = $BE SYMBOL SkipROM = $CC SYMBOL Graad = 223 SYMBOL DS1820 = PORTA.1 SYMBOL verwarming = PORTA.6 DIM Temp AS WORD DIM Remain AS BYTE DIM Slope AS BYTE DIM BD1 AS BYTE -------- OWRITE DS1820, 1, [SkipROM, Convert] OWRITE DS1820, 1, [SkipROM, RdScratchPad] OREAD DS1820, 2, [Temp.LOWBYTE, Temp.HIGHBYTE, BD1, BD1, BD1, BD1, Remain, Slope] ',CRC] Temp = (((Temp >> 1) * 100) - 25) + (((Slope - Remain) * 100) / Slope) PRINT AT 1, 1, DEC Temp / 100, ".", DEC1 Temp / 10, Graad, "C "
by the way, verwarming is dutch... but doens't mather... it's just a symbol
[/edit]
But how can i control the LED with the code above? I used a IF then ELSE statement on Temp but Temp shows only symbols (not with DEC in front of it at the PRINT line, so not on LCD with that code)
[edit2]
When i use this, just for example what Temp do without DEC, I get the most funnyest symbols and icons on LCD
Anyhow... I need to put it in a If then Else statement... to control the ledCode:PRINT AT 1, 1, Temp
[/edit2]
