Hi, Scootie
First thought ...
WHICH Pic are you using
Second thought ...
Your FULL program ( " copied and pasted " - not re-written - ) would be useful here
Third Thought ...
a nice FULL SCHEME would be interesting to verify everything
Hi, Scootie
First thought ...
Second thought ...
Third Thought ...
It's alright Alain, just gaze into your crystal ball and I'm sure you'll find all the answers![]()
... and what crystal you are using???
From the manual
RCTIME may be used to read a potentiometer (or some other resistive
device). Resistance can be measured by discharging and timing the
charge (or vice versa) of a capacitor through the resistor (typically 5K to
50K).
The resolution of RCTIME is dependent upon the oscillator frequency. If
a 4MHz oscillator is used, the time in state is returned in 10us
increments. If a 20MHz oscillator is used, the time in state will have a
2us resolution. Defining an OSC value has no effect on RCTIME. The
resolution always changes with the actual oscillator speed.
Hopefully these code tags show up properly and this is the place to paste the code, I am new at this
Code:' Name : dtime.pbp ' Compiler : PICBASIC PRO Compiler 2.60 ' Assembler : PM or MPASM ' Target PIC : 40-pin 16F887 ' Hardware : Lab-X1 ' Oscillator : 20MHz external crystal 'set device type 'fl pic16f887 ' Define LCD registers and bits DEFINE LCD_DREG PORTD Define LCD_DBIT 4 Define LCD_RSREG PORTE Define LCD_RSBIT 0 Define LCD_EREG PORTE Define LCD_EBIT 1 ANSEL = %00000001 ' Set AN0-AN7 to digital with the exeption of AN0 ANSELH = %00000000 ' Set AN8 and higher channels to digital operation '********************************************************** dtime VAR WORD res1 VAR WORD res2 VAR WORD res3 VAR WORD 'Set up cap = 2uf pin b.5 to VDD 'nom resistance b.5-b.6 350ohm 'nom resistance b.5-b.4 5ohm 'TRISA = %11111111 ' Set PORTA to all input Low PORTE.2 ' LCD R/W line low (W) PAUSE 500 ' Wait .5 second mainloop: 'measure strain gage resistance TRISB.6 = 0 TRISB.4 = 1 HIGH portb.6 LOW portb.5 PAUSE 10 RCTIME portb.5,0,dtime res1 = ((dtime*175)/10) 'measure wiring resistance loop TRISB.6 = 1 TRISB.4 = 0 HIGH portb.4 LOW portb.5 PAUSE 10 RCTIME portb.5,0,dtime res2 = ((dtime*175)/10) res3 = res1-res2 LCDOUT $fe, 1 ' Clear LCD LCDOUT "Raw ", DEC res1 ' Display value R1 LCDOUT $fe, $88 LCDOUT "Wirie ", DEC res2 ' Display value R2 LCDOUT $fe, $c0 LCDOUT "Gage ", DEC res3 ' Display value R3 PAUSE 1000 ' Wait 1 second GOTO mainloop End
I figured out that when I put in another pause my origional problem went away and it didn't matter what order the outputs were set in. Still don't know why though
Also changed the port bits because the others caused a porblem with the programmer left plugged into the x1 board
I need a larger (but stable) capacitor than the 2uf I am using now. The count is so low that I don't get the tolerance I need, each step is about 17.5 ohms and I would like to have about 1.0 ohm resolution if possible. My parts drawers don't have any good choices though.
Code:TRISB.0 = 0 TRISB.2 = 1 HIGH portb.0 PAUSE 10 LOW portb.1 PAUSE 10 RCTIME portb.1,0,dtime
