Assistance Required with VB.net
Results 1 to 33 of 33
Threaded View
  1. #12
    Feb 2010
    I live in the UK
    I'm trying to send data from PIC - PC using the program mackrackit pointed to earlier in this thread.
    http://www.rentron.com/receiving_data.htm
    When I compile it I have this error message: Name 'comEvReceive' is not declared.
    Does anyone have an idea of a fix (with as much of an explaination as you can spare please, I'm new to this). I've done lots of Googling with various answer from 'Select Case' to it can't be done in the 2008 VB-Version.
     Private Sub MSComm1_OnComm()
    Dim sData As String ' Holds our incoming data
    Dim lHighByte As Long   ' Holds HighByte value
    Dim lLowByte As Long    ' Holds LowByte value
    Dim lWord As Long       ' Holds the Word result
    ' If comEvReceive Event then get data and display
    If MSComm1.CommEvent = comEvReceive Then
        sData = MSComm1.Input ' Get data (2 bytes)
        lHighByte = Asc(Mid$(sData, 1, 1)) ' get 1st byte
        lLowByte = Asc(Mid$(sData, 2, 1))  ' Get 2nd byte
        ' Combine bytes into a word
        lWord = (lHighByte * &H100) Or lLowByte
        ' Convert value to a string and display
        lblRCTime.Caption = CStr(lWord)
    End If
    End Sub
    I guess I should add I'm using Visual Basic 2008 Express Edition.
    Any help much appreciated.
