Help with A/D math!
Results 1 to 16 of 16
    Jul 2010
    Alain,
    Wow, works like a charm... now can you tell me how you got to those numbers? <grin>
    I'm sure when I install this in the field I will have different numbers, so I will need to know how to recalculate.
    You are a lifesaver!
    Quote Originally Posted by dbodenheimer View Post
    Alain,
    Wow, works like a charm... now can you tell me how you got to those numbers? <GRIN>
    Very simple, Dave ... no miracle !
    just need to check what is PBP compatible , as an operation, and avoiding any overflow when calculating ...
    Have a look here ...
    http://curveexpert.webhop.net/
    really a very handy tool
    Jul 2010
    Got the tool. Yes it looks very handy!
    Can you tell me the setup you used to calculate the data i sent?
    I want to make sure i understand how to set things up
    Thanks!
    Jul 2010
    Lightbulb
    Enter data into “CurveExpert” chart:
    X is distance, Y is A/D data
    Select ‘Apply Fit”, select ‘Linear” from drop down menu.
    A graph will pop up, press the ‘info’ button and you’ll get your equation and the coefficients to use.
    I will never admit how long that took me to figure out.
    Quote Originally Posted by lavenatti View Post
    Hi, Lavenatti
    Quite Easy to believe...
    Didn't you just swap here input and output values ???
    Mar 2011
    Bangkok Thailand
    Default Re: Help with A/D math!
    Hello
    This was very interesting. I have a little bit of the same problem.
    I have A/D input 0-5V (0-255)
    I want a puls out 0V=1mS and 5V=2mS.
    If i take your example with the Laser and run it in CurveExpert i got the formula a-bx.
    Where did you get 8573 and 41 from, and what is + ( AdResult / 2 ) means?
    distance = 8573 + 41*AdResult + ( AdResult / 2 )
    Any help will help.
    How about:
    ADResult = ADResult * 10
    DelayInMicroSeconds = 1000 + (ADResult */ 100)
    PortB.0 = 1
    PauseUs DelayInMicroSeconds
    PortB.0 = 0
    When ADResult is 0 DelayInMicroSeconds is 1000 (1ms), when ADResult is 128 you'll get 1000 + (1280 * 100 / 256) = 1500 and when ADresult is 255 DelayInMicroSeconds is 1000 + (2550 * 100 / 256) = 1996.
    It's not perfect but hopefully good enough.
