Do a search for Pic Multicalc, it's very useful for setting up the defines etc.  Entering an osc of 4Mhz and 3400 or 57600 it gives these values
DEFINE HSER_SPBRG 6   ' 38400 Baud @ 4MHz, -6.99%
DEFINE HSER_SPBRG 0   ' 57600 Baud @ 4MHz, 8.51%
 You could try these values, however for running at a fast baud rate I would recommend using a 20Mhz crystal on the 16F877A with the following defines
	@   __config _HS_OSC
DEFINE  OSC 20
DEFINE HSER_BAUD    115200        ' Hser baud rate
DEFINE HSER_RCSTA   90h           ' Hser receive status init
DEFINE HSER_TXSTA   24h           ' Hser transmit status init
DEFINE HSER_SPBRG 10                ' 115200 Baud @ 20MHz, -1.36%
DEFINE HSER_CLROERR 1             ' Hser clear overflow automatically
