The circuit amplifies the signal coming from the sensor by about 127,000 times. The high-frequency cutoff is around 500Hz.
Charles Linquist
Since the 2nd opamp is functioning as an integrator, no pulses are output.
It is a filtered pure analog signal. So you need to acquire it by the A/D module of your controller.
What you are going to do next is a matter of programming.
You may have to look for rapid changes of the signal.
An Osciloscope would help here alot.
