RX LO is just the local oscillator frequency fed into the mixer on a superhet receiver. When you change the TX frequency, it also has to change the receive frequency.
Check http://en.wikipedia.org/wiki/Superheterodyne_receiver and scroll down to the Overview section for a brief explanation, or lookup superhet receiver design online for the nitty-gritty details.
Also - the HP3 series serial communications will not work with DEBUG or any other asynchronous (means no clock) since it is synchronous (means it requires clock & data) serial.
Check out http://linxtechnologies.com/Documents/AN-00155.pdf for a code example of serial communications with an HP3 series.
because on TX datasheet it says clearly that what to send and what will be the TX frequency, BUT on RX datasheet it doesn't say what to send and what will be the RX centre frequency, instead it mentions excatly the same thing as in the TX datasheet, which I think is only for changing TX channel. It may be a small thing to undertstand but I am still not getting it clearly.
