16F886 Config & Defines
Results 1 to 5 of 5
    I do not use PM, so this is how I set it up using MPASM.
    @ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
       OSCCON = %01110000
       DEFINE OSC 8
       CM1CON0 = 0 			'Comparator Off
       CM2CON0 = 0 			'Comparator Off
       TRISA = %11111111 		'SET PORTA AS INPUTS
       TRISB = %00000000 		'SET PORTB AS OUTPUTS
       TRISC = %11111111 		'SET PORTC AS INPUTS
       ANSEL = %00001111		'SET INPUTS AN0-AN3 AS ANALOG INPUTS
       ADCON1 = %10000000		'SETUP ADC RIGHT JUSTIFY SET REFV to VDD & VSS
    'Define ADCIN parameters
    	Define ADC_BITS 10 		'Set number of bits in result (10)
    	Define ADC_CLOCK 3 		'Set clock source (3=rc)
    	Define ADC_SAMPLEUS 50 		'Set sampling time in microseconds (50us)
    Not much different than yours...
    Can you explain __config _CONFIG1 ?
    I understand the other statements on that line.
    Thanks peter
