lcdout $fe,$94,"Top Speed ",#PeakSpeed," FPS"
You are using 14 spaces in the above with text, then what ever the VAR is using. Add that to the four blank spaces, $94, you might be running out of spaces?
You might try
lcdout $fe,$90,"Top Speed ",#PeakSpeed," FPS"
