How can I speed this code up? SHIFTOUT is slowing it down and I need a faster way.
Results 1 to 30 of 30
Threaded View
  1. #19
    Dec 2007
    Finland
    Default How about ASM replacement for PBP Shiftout?
    Hi Wolwil,
    You could replace PBP SHIFTOUT with attached ASM code example and reduce time spend in SHIFTOUT + loop to ~1/8. This is kind of tested, but no promises ... Check if it is usefull for you.
    PBP_shiftout execution time was around 814uS, but ASM_shiftout took only 104uS to do the same.
    Files:
    PBP_shiftout.pbp.txt <- Original, copied from 1st post
    ASM_shiftout.pbp.txt
    (Just remove .txt from end of files)
    I know that ASM version is spaghetti code but I don' really care
    So long time since last time when I did something with ASM.
    BR,
    -Gusse-
