Mmm. Well I kind of think I know what I have to do, it's break the VAR WORD Total up into two BYTES, allocate them each a memory space B1 & B1+1 (from the prog below) WRITE the BYTES to the memory locations then READ them back.
My reading of the program above is that B1 = 's ( 0,2,4,6,8,10,12) + 1000 this is then written and read from memory location B1 & B1+1 into WORD W2 am I close?Code:INCLUDE "modedefs.bas" ' Include serial modes SO VAR PORTC.6 ' Define serial output pin B1 VAR BYTE ' Address variable W2 VAR WORD ' Data variable mainloop: For B1 = 0 To 12 step 2 ' Step 2 because each word requires 2 bytes of memory W2 = B1 + 1000 ' Add 1000 to address Write B1, W2.HIGHBYTE ' Write high byte of word Write B1+1, W2.LOWBYTE ' Write low byte of word to next address Next B1 For B1 = 0 To 12 step 2 ' Step 2 to get word size data Read B1, W2.HIGHBYTE ' Read high byte Read B1+1, W2.LOWBYTE ' Read low byte SerOut SO,T2400,[#W2," ",10,13] ' Display the word data Next B1 SerOut SO,T2400,[10,13,10,13] ' Skip 2 Lines GoTo mainloop ' Forever
