SHIFTOUT is not working
Results 1 to 3 of 3
    Jul 2009
    UPDATE:
    PROBLEM SOLVED!
    In case anyone else has the problem I did - i.e. SHIFTOUT not generating any signals, here is how I solved it:
    I should have followed the three standard debugging rules when it comes to odd behaviour in PICs:
    1. Check the MCLR pin isn't held low (it wasn't)
    2. Check there is a clock signal (there was)
    3. Check the CONFIG bits - HERES THE PROBLEM!
    I went through all of the CONFIG options and discovered that with Extended Instruction Set enabled SHIFTOUT did not work, but as soon as it was disabled everything worked as expected!
    I guess the simulation doesn't differentiate between extended and non-extended and just works in either case.
    Hope this helps anyone who has the same problem.
    France
    Default ****out problem
    Thanks for your message, but what do you mean by " Extended Instruction " ?
    bye the way, I have a problem, not the same but ...
    I try to use also the SHIFTOUT command to send data to a PLL (via Clock and Data pins)
    I use the mode (1 or 5) but the clock is always at HIGH level and there is just a DOWN pulse
    From the help explanation (clock idles high or low) my understanding was
    clock idles low .... clock signal is at LOW level and a positive pulse occur
    clock idles High ... clock signal is at HIGH level and a négative pulse occur
    as I said I try mode 1 or 5, and I see NO difference on the oscilloscope !
    any idea ?
    thanks
    Francois
    Quote Originally Posted by awmt102 View Post
    UPDATE:
    PROBLEM SOLVED!
