Chris,
Accessing your vars in your asm routine without knowing which bank they're in, or handling BSR, is most, if not all, of the problem I suspect.
If all of your vars will fit into 1 bank, just tell PBP to place them all in the same bank, then set BSR to this bank on entry to your int handler.
