EEPROM life
Results 1 to 6 of 6
Thread: EEPROM life
    What constitutes a WRITE cycle
    The completion of a successful write to the memory cell or block of cells.
    Flash Program Memory is erased/written in blocks of 32 words - or 64 bytes. So you have up to 100K writes to here before it gets into the failure range.
    Data EEPROM can be written in single bytes - with up to 1M writes 'per cell' before it gets near end-of-life.
    Just testing, i've pushed EEPROM memory beyond 5M writes, and it kept working just fine, but I wouldn't shoot anything like that out onto the market.....
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2007
    Note that both of those parameters are device specific.
    Sep 2005
    Campbell, CA
    Thanks guys!
    I, too have pushed EEPROM cells to over 2M WRITES, but my military customers are interested in MTBF. If I use the "approved" tables, the
    MTBF of my entire unit starts decreasing significantly if I have more
    than 100K WRITES.
    My plan was to write a word into two bytes, and when it overflowed,
    increment another EEEPROM cell (which tells me the byte offset) and shift the WRITE up one byte.
    That way, each cell would get 65536 + 256 WRITES.
    I was worried that if I just shifted up one byte each time I overflowed,
    I would actually be writing more times than I thought.
    Charles Linquist
    May 2007
    Check out AN1095 from MC's website. Slightly different application (Emulating Data EEPROM for PIC18 and PIC24 Microcontrollers and dsPIC® Digital Signal Controllers) but there are some interesting techniques in it, eg. increasing Total Effective Endurance by a factor of 1,000.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. EEPROM life expectancy?
    By muddy0409 in forum General
    Last Post: - 1st May 2007, 12:44
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
