Need help with LM34 and 12F675
Results 1 to 11 of 11
    That is the way the LM34 is when running on 5 volts. Figure the steps in 8 bit and all that.
    If you want a 1 degree resolution set up the VREF and have the reference voltage at 3.3 volts.
    Then in place of multiplying by 2
    you would use
    ADC_VAR * 4 / 3
    At least that works for me
    Glad you got it going.
    Nov 2009
    Wagoner, USA
    you would use
    ADC_VAR * 4 / 3
    Thanks for the tip. I'll have to try to find a 3.3v reference tomorrow. I have some 1.25's but that's a little shy.
    The LM34 is doing what it's supposed to. It is putting out .700v at 70 degrees but the pic reads it as .350v.
    Thanks..
    malc-c's Avatar
    malc-c Guest
    Interesting thread, and quite by chance similar to a project I was contemplating.
    I was thinking of making my own pulse proportional thermostat for use with reptile enclosures. Your code could be the ideal starting point for me, thanks for sharing
    Nov 2009
    Wagoner, USA
    Quote Originally Posted by malc-c View Post
    I've made a couple of changes since I posted that. I'm using the plusout command instead of the PWM command. There is better control with the pulsout command.
    I've also added an external thermostat to turn it off. Man does it get hot!
    GPIO.1 is pulled low through a 10k then goes to VDD through a wall thermostat.
    Here is the final working code:
    'LM34 F temperature sensor
    'PIN  NAME     Purpose
    ' 1    VDD      +5v
    ' 2   Output    10mv/degF, +5° to +300°F = 50mv-3000mv
    ' 3    VSS      GND
    'PIC12F675
    ' PIN  NAME     Purpose
    '  1    VDD     +5v VDD
    '  2   GPIO.5   Serial out for debug
    '  3   GPIO.4   PWM out to servo
    '  4   GPIO.3   ***Programmer VPP
    '  5   GPIO.2   Output to NPN transistor sinking relay.
    '  6   GPIO.1   Input from thermostat /***Programmer Clk
    '  7   GPIO.0   Analog input from center leg of LM34 /***Programmer Data
    '  8    VSS     GND VSS
    '********************************* Fuses ******************************
    @ device pic12F675, intrc_osc_noclkout, wdt_off, pwrt_on, mclr_off, bod_off, protect_off
    '********************************* Setup *******************************
    DEFINE debug_mode 1     '0=True, 1=Inverted serial data
    DEFINE debug_bit 5      'sends serial data out GPIO.5 at N,8,1
    DEFINE debug_baud 2400  'Default baud rate = 2400
    DEFINE osc 4            'We're using a 4 MHz oscillator
    Define OSCCAL_1K 1      'Set OSCCAL for 1K device
    DEFINE ADC_BITS 8       'Set A/D for 8-bit operation
    DEFINE ADC_SAMPLEUS 50  'Set A/D sampling time @ 50 uS
    CMCON=7                 '(%00000111) Turn off analog comparators
    TRISIO=%00001011        '001001 Port direction register. GPIO.0 & GPIO.3 =inputs (.3 is always input)
    ADCON0=%00000000        '00000000 Left justified,Vref=VDD,GP.0=ANALOG INPUT
    ANSEL=%01010001         '01010001 FOSC=16=101,GPIO.0=analog
    Samples VAR WORD        'Multiple A/D sample accumulator
    Sample  VAR BYTE        'Holds number of Samples to take
    Temp    VAR BYTE        'Temperature storage
    Thermostat var bit      'Input from thermostat
    Relay   var GPIO.2      'Variable for relay output
    LowTemp con 90          'Turn off relay
    HighTemp con 110        'Turn on relay
    Samples = 0             'Clear Samples accumulator on power-up
    '****************************** Servo Stuff ****************************
    Servo  var GPIO.4       'Variable for PWM output
    low servo               'Initilize GPIO.4 to low
    Accum var byte          'GP Accumulator variable
    AccLow con 100           'Accumulator Min pulse (move CCW)
    AccHigh con 250         'Accumulator Max pulse  (Move Cw)
    Wait1 con 20            'Delay before repeating loop
    Flag   var bit          'Holds bit for servo position
    flag=0                  'initilize flag
    PAUSE 500               'Wait .5 second
    '********************************* Main ********************************
        FOR sample = 1 TO 20    ' Take 20 Samples
            ADCIN 0, temp       ' Read channel 0 into temp variable
            Samples = Samples + temp ' Accumulate 20 Samples
            PAUSE 250           ' Wait approximately 1/4 seconds per loop
        NEXT sample
            temp = Samples/20*2
            if temp >lowtemp and temp>hightemp and thermostat=1 then gosub onrelay
            if temp <=lowtemp then gosub offrelay
    DEBUG "Curr Temp: ",DEC temp,"° F ",10,13,10,13," Off Temp: ",dec lowtemp,"° F "," On Temp: ",dec hightemp,"° F ",10,13
    DEBUG "CCW Pulse Width: ",dec Acclow,"ms ", "CW Pulse Width: ",dec Acchigh,",ms ", "Flag: ",dec flag,10,13
               Samples = 0      ' Clear old sample accumulator
        GOTO main               ' Do it forever
    '******************************* Output **********************************
    OnRelay:
            high relay           'Turns on GPIO.1
            if flag=0 then gosub VentOpen  'If vent is closed then open it.
    OffRelay:
            low relay            'Turns off GPIO.1
            if flag=1 then gosub VentClosed 'if vent is open then close it.
    '**************************** Open Damper ********************************
    '@@@@@@@@@ SWAP LINES 75 & 76 AND LINES 84 & 85 TO REVERSE ROTATION @@@@@@@@@@@@
    VentOpen:
        for Accum=acchigh to acclow step -1 'Move servo 90 deg CW
        'for Accum=Acclow to acchigh  'Move servo 90 deg CCW
            pulsout servo, Accum
            pause Wait1
        next
    	    flag=1            'Set Flag to tell when open
    '**************************** Close Damper *******************************
    VentClosed:
        'for Accum=acchigh to acclow step -1 'Move servo 90 deg CW
            pause Wait1
        next
    	    flag=0            'Set Flag to tell when closed
    Hi, Malc
    I think there's something for you here ...
    http://www.parallax.com/Portals/0/Do...oks/edu/ic.pdf
    have a nice time ...
  1. 12f675 sensing temperature...
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 6th April 2007, 01:11
