decoding quadrature encoders
Results 1 to 40 of 94
    Italy
    File attachment = Incremental quadrature encoder direction drawing.
    Luciano
    ice's Avatar
    ice Guest
    Luciano>>
    Thanks for the file..i figured out the logic of the "XOR"..
    i included this in my code...[the counting up and counting down lines]
    quad:
    	new= PORTC & %00000011
    start:
    	old=new & %00000011
    again:
    	IF new=old Then again
    	direction_bit=old.bit1 ^ new.bit0
    	IF direct=0 Then  cw
    	LCDOut $fe,1,"Last was CCW"
    	counter=counter+1
    	LCDOut $fe,$c0,DEC counter
    	Pause 5
    	GoTo start
    cw:
    	LCDOut $fe,1,"Last was CW"
    	counter=counter-1
    	Pause 5
    	GoTo start
    ...I am able to see the counter going up and down as the motor changes it's direction..however the LCD line "last was cw/ccw"..keeps on flipping and never remains the same..even if the motor has moved in the same direction..
    Im still working on it..and will keep u all posted...
    monitor the 'value' variable. or modify it easily to have CW and CCW flag in one shot....
    Thanks for the link M_e
    ..i'll be doing tht to take care of the above problem
    Italy
    Try this code. (Not tested).
    (Problem in your code: you use 'direction_bit' but also 'direct').
    Luciano
    	old_val VAR BYTE
    	new_val VAR BYTE
    	direction_bit VAR BIT
    	enc_counter VAR WORD
    	enc_counter = 10000
    	new_val = PORTC & %00000011
    start:
    	old_val = new_val
    again:
    	IF new_val = old_val Then again
    	direction_bit = old_val.bit0 ^ new_val.bit1
    	IF direction_bit = 1 Then
    		enc_counter = enc_counter + 1
    		LCDOut $fe,$c0,DEC enc_counter
    		enc_counter = enc_counter - 1
    	GoTo start
    May 2007
    Thumbs up
    Quote Originally Posted by Luciano View Post
    Luciano
    Luciano: five stars!
  1. Quick thoughts: DT Ints with encoders
    Last Post: - 7th January 2010, 01:01
  2. PMDC SERVO MOTOR WITH quadrature encoder DRIVE ?
    By phoenix_1 in forum Schematics
    Last Post: - 22nd November 2009, 19:45
  3. 32-bit Quadrature Counter With Serial Interface
    Last Post: - 10th June 2008, 02:49
  4. quad encoders
    Last Post: - 13th March 2007, 17:49
  5. "momentary" IR decoding
    By sporker in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 01:53
