ADC Averaging
Results 1 to 5 of 5
Thread: ADC Averaging
    The amount of data you collect before averaging is pretty much a personal prference. If the value does not swing much then more is a waist of time. Large swings withe the most being mid range then you need to collectet enough to cover it all.
    To do he averaging. Set up a loop reading the ADC for the amount you want to collect. Keep adding the VAR to it's self then divide when finished.
    Bombay, India
    Sep 2009
    Hey,
    for 10 bit ADC, if the value is not ranging much, what should be the number of samples to be taken?
    Thanks for the reply.
    Take a couple of dozen samples...
    Sort them...
    Discard the top six values...
    Discard the Bottom six values...
    Sum and average the middle twelve.
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 16:33
  3. adc averaging readings
    By amgen in forum mel PIC BASIC Pro
    Last Post: - 21st June 2006, 01:57
  4. ADC value with 2 decimals on an LCD
    Last Post: - 2nd December 2005, 16:54
  5. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 02:55
