Optically Isolated Phase Controlling Circuit
Results 1 to 11 of 11
    Actually my point was that in the first schematic the H11L1 is providing isolation from the supply to the 555, in the second it is provided by the Transformer - which makes it kind of pointless having it still in circuit. Also that Transformer is 12-0-12... is there a reason you want to run your Trigger circuit at 24v?
    Blindly copying other peoples schematics is one thing... but modifying them without actually knowing what they do is another (kinda like all the cut & paste that goes on in this forum I suppose)...
    Jul 2009
    I am developing a remote control system using microcontroller, my project is not only control fan regulators, its also control lamps etc. So I add more than 10 relays for switching lamps. My all relays are using 12v. So the 12volt transformer is using for other purpose also like relays etc not only for above mentioned schemetic.
    May 2008
    Italy
    Try this way it should work.
    Than place an oscilloscope on pin 2 of LM555 and you should see a pulse every 8,3 milliseconds (if your main is 60 Hz) or every 10 milliseconds ( if your main is 50 Hz)
    Al.
    Jul 2009
    Thumbs up Thanks.....
    Quote Originally Posted by aratti View Post
    Al.
    Thank you so much aratti.
    Ok I am going to build with your way, but I like know that what are the problems in my circuit, you said H11L1 is on all time, so zero crossing detecter should not work. When I am looking your way, the main differents is you are not avoiding zener diode (D5) and H11L1 parallel resistor (R2) right? On EFY Magazine circuit both components are not using, but that is working circuit. For getting knowlege, can you please explain why zener diode (D5) and resistor (R2) is used in this circuit?
    And also please tell me, if I want trigger upto twenty five LM555 for controlling upto 25 fan, which transistor I need to use instead of MPSA40. Is this transistor has enough current to trigger upto 25 LM555?
    May 2008
    Italy
    Detecting the zerocrossing correctly (without delay) is not a simple metter. Here we have got to thrust Fairchild engineers.
    When you have got a working circuit, with the proper zerocrossing pulse detected by your oscilloscope, then tray to remove some components you judge useless and see the result on your scope. If pattern doesn't change you were right otherwise you will have to resolder the component in its original position.
    This is the best way to learn.
    I don't recommend to use this solution having a long wire connected to pin 2 of LM555 will works as an antenna with unpredictable results.
    You should have 25 complete circuits, you can supply the 12 Vac directly to all 25.
    Al
    Jul 2009
    Thumbs up Thanks Again
    Al
    I am not trusting EFY Magazine schemetic that why I am using Fairchild schemetic. EFY Mag is Indian edition. I am developing this project is for business purpose, so I need quality product. Good reply and thanks.
  1. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 08:54
  2. Circuit reliability issues
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2007, 15:55
  3. Replies: 3
    Last Post: - 29th October 2006, 10:16
