RF transmission and FSK modules
Results 1 to 10 of 10
    OK. Thank. Digi has new devices for over 40Km range although these do not support the Zigbee stack.
    Hope they will update the firmware.
    I tried them and seems that this is true. Also powe can be adjusted for lower consumption.
    Modules are small enough.
    I know.
    The project which got me into all this stuff was a remote machine monitoring project.
    The ultimate hardware, for me, is the 6LowPAN protocol. Here, each node gets an IPV6 IP address and messages can therefore be routed to them directly via the internet without any translation.
    Unfortunately, 6LowPAN implementations are thin on the ground, and I didin't get a large enough grant to buy the units from Sensinode which are the best application of 6LowPAN I've seen so far.
    AVR (boo hiss) make a development board called a 'Raven' and there is a free RTOS and 6LowPAN implementation for use with those boards but then each node needs a Raven board.
    IPv6 is very new to me. But having a lookat Sensinode site, made me think all stuff I used so far are ancient technology!
    Very interesting devices.
    Wish we had independancy from money and do all the things we dream.
    I am in talks with a client to develop a network for banks so that they can control from the headquarters every stuff connected to the net. Many nodes may need wireless connections and zigbee seems a good idea.
    If you feel like in discussing these projects I would be happy on private e-mails exchange.
    Ioannis, I might get in touch with you soon but other work is backing me up at the moment.
    There are _a lot_ of private protocols, all designed with different uses in mind, and Zigbee is just one, and from what I hear is as much a money making system as it is a desire to build the best networking system.
    For full industry standards compliance you should look at Dust Networks
    http://www.dustnetworks.com/products/
    Mesh wioreless networking with HART standards
    They were recommended to me by an engineer who had implemented the wireless mesh system on oil rigs to provide roller bearing wear and vibration information. (The sensor is powered by a coil and magnet revolving within the bearing itself !)
    Arch Rock seem to have started shipping their 6LowPAN solution, called Phynet
    http://www.archrock.com/products/phynet_router.php
    I would have tried to use it if it had of been released 6 months earlier, but not to worry !
    Chris
    Thanks for the links Chris. Seems that my weekend will be spent on reading!
  1. RF Transceiver modules help
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 16th May 2008, 14:54
  2. supply FSK COB modules and FSK modules
    By Elsa zhang in forum Adverts
    Last Post: - 8th August 2006, 06:40
