DT Interrupt and Elapsed Time Running Slow
Results 1 to 10 of 10
    Apr 2009
    Boise, Id
    Thanks Darrel, I removed the indent on the "INT_LIST" macro, that took care of the warning. I never thought an indent would make a warning, I searched high and low in my code and your's for any references to "INT_LIST".
    I also stopped changing T1CON settings, I didn't realize you're code was already setting it up.
    I still haven't fixed the debug issue. I thought a quick fix would be to disable the interupts before sending the data out on debug, that didn't work.
    So now I'm learning about the USART you suggested, which has me confused. How do I use the USART without using "SEROUT" if the interupts will interfer with SERIN/OUT?
    Any help on configuration would be great!
    Shane
    Quote Originally Posted by ShaneMichael View Post
    Disabling the interrupts will disrupt the Elapsed Timer if they are turned off for more than 1/100th of a sec.
    HSEROUT and HSERIN are for the USART.
    Apr 2009
    Boise, Id
    Huh, look at that, HSEROUT is for the USART. Glad you said that, I'm reading the book on SEROUT and going in circles with interupts messing with SERIN/OUT.
    I'll see what I can get going with HSEROUT. I'm sure I'll have more questions as I progress. At least I'm not just trying random settings any more, that's progress!!!
    Shane
    Apr 2009
    Boise, Id
    OK, HSEROUT is working, and so is the timer interupt. After almost 30 minutes, it was slow about 20 seconds. I'm guessing that could be drift in the internal OSC? It's all I'll need for the current project.
    I used the HSEROUT settings from the PBP manual, I compaired them to the data sheet for the 18F2550, I didn't see anything that I felt like I should change. Learned my lesson with the T1CON settings.
    Thanks for the help.
    For those reading this that are worried about changing from Debug to HSEROUT, it wasn't bad, I used the following Defines:
         DEFINE HSER_RCSTA  90h
         DEFINE HSER_TXSTA  20h
         DEFINE HSER_BAUD   9600
         DEFINE HSER_CLROERR    1
    The HSEROUT looks like this:
    Hserout [10," M: ",dec Minutes," S: ",dec Seconds," T: ",dec Ticks,10]
    I'm using the "Serial Communicator" in MicroCode Studio (F4 key)
    The pic is connected to a MAX232, I think this is needed for HSEROUT? Someone correct me if I'm wrong.
    Also I'm using a DYNEX RS232 to USB adapter:
    Model: DX-UBDB9 from BestBuy
    I'm Using Windows VISTA, so I downloaded the latest drivers from their website, and only had moderate issues with VISTA ( mostly operator error )
    Hope this helps out anyone else that has questions about a setup.
    Shane
    Default 20h or 24h ?
    The HSER_TXSTA should be 20h or 24h ?
    Using the internal OSC sure leads to problems one day or another, even with newer OSC accuracy.
    @8MHz and 9600 baud, it shouldn't matter if you use 24, or 20 for TXSTA as both will return the same error %... BUT assuming some ASM limitations, asking PBP macro to calculate the SPBRG value for you, could give some difference at this point.
    See what a single digit of difference can do
    @8MHz and TXSTA=20,
    if SPBRG=11, err% =8.507%
    if SPBRG=12, err% =0.16
    if SPBRG=13, err% = -6.994%
    When TXSTA=24
    if SPBRG=50, err% =2.124%
    if SPBRG=51, err% =0.16
    if SPBRG=52, err% =-1.73%
    Play safe and set SPBRG yourself.
    DEFINE HSER_SPBRG 12  ' 9600 Baud @ 8MHz, 0.16%
    This is where I begun to think about some Standalone Calc software. First was E-Z SPBRG Calculator, then it grows and became PicMultiCalc.
    Download it
    http://www.picbasic.co.uk/forum/atta...7&d=1225550328
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. Interrupt RPM and Taylors Elapsed time on 18F4620
    Last Post: - 3rd February 2010, 17:12
  3. Get elapsed time while TIMER samples pulses
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 17:27
  4. Interrupt problem.
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 13th August 2005, 07:40
  5. My Code get crazy after i add interrupt
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 10th May 2005, 05:43
