Don't fall into the trap that a PIC is a panacea for all your problems... half the forum thinks that way and then they discover after a lot of wasted time and effort these little things sometimes need external help to accomplish some tasks - and multi-channel complex signal processing is one of them.
0603 size Resistors and Diodes are still very much hand solderable with a pair of tweezers and a steady hand. You quickly tack one end with a soldering iron so it anchors, solder the other end properly, then go back and solder the first end properly. If you're building a one-off it won't matter. Trust me, you WILL need to rectify and filter those inputs. You are going to waste a shed-load of time and effort and end up with mediocre results going down the route you plan.
The final output from the Guitar to the Amp is a sum of the individual strings anyway. You can always build an external 'in-line' box which has the added advantage that it can be fitted to any Guitar without voiding manufacturers warranties etc. If you do it using Thermionic Valves (a single ECC83 or any twin-triode equivallent will make an eminent AGC and pre-amp) you will have a queue of people breaking your door down to get one (since valves and stage gear are very much in vogue).
