PIC16F616 HWPM Problem
Results 1 to 4 of 4
    Come on isn't that just a minor technical difficulty??? I thought I was doing good reading the spec sheet. Table 2 has RC5 as CCP1, I thought that I could get away using RC2,3, and 4 because there was P1B, P1C, and P1D. What would I use RC2, 3, and 4 as if they are labeled as P1B, P1C, and P1D? Does that mean I can use them as HPWM's yet they will share the same pulse width as the CCP1? For my project I need two different PWM's so I would need a chip that has two CCP's?
    Toby
    Quote Originally Posted by Tobias View Post
    Insignificant, in the scope of world events. <hr>
    The CCP module on that chip is an ECCP.
    The P1A thru P1D outputs can be used to run "half-bridge" or "full-bridge" motor drivers and a few other tricky things. All the outputs would have the same PWM freq/duty, but uses complimentary signals with programmable delays when switching states.
    But the way the HPWM command uses the CCP module, it's a single output on the CCP pin.
    You can only get 1 PWM signal out of it.
    Depends on what you need. There are alternatives to HPWM.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. Problem with servo and PIC16F616
    By Forkosh in forum mel PIC BASIC Pro
    Last Post: - 18th November 2007, 21:22
  3. PIC16F616 Comparator problem
    By JimA in forum General
    Last Post: - 15th October 2007, 14:56
  4. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
