New PIC failure rate
Results 1 to 6 of 6
    Of the PICs you mention, we use thousands of the 16F628A and the 18F2420... we DON'T do ICSP but always program them before fitting...
    We've NO problems with the 16F628A apart from we have discovered that executing an ERASE before programming eliminates 1st time programming errors (even on factory new parts). This is something to we routinely do on all PICs now - not just on this one.
    There are unexplained anomalies with the 18F2420... whilst it programs just fine, about 3% have a problem with PORTB.7 on one particular application which tends to go away if you reprogram the PIC a second time. We had a batch in the summer of 2007 which were really flaky and unstable with regard to internal EEPROM which became corrupted very easily. It's a device that comes up with surprises from time to time...
    Jul 2007
    Hi Melanie,
    What company do you work for
    timmers's Avatar
    timmers Guest
    Hi Melanie,
    Thats interesting about the erase, had never thought of doing that. Our programmer erases before programming anyway, but I will mention that to the factory chaps and see if it helps.
    18F2420 is a recent transition from 16F876 to give us more memory. I pressume the 18F2520 suffers similar problems?
    Many thanks
    Tim.
    High likely a device programmer issue. Might worth to try all their software & driver upgrade
    http://www.quasarelectronics.com/micropro.htm
    Silicon issue, is also possible... depending where you get them from...
    Brussels, Belgium
    I've got a 60% programming failure rate on 18F4431 devices purchased from Microchip Direct this year.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  3. PIC ROM erase failure
    By shahidali55 in forum General
    Last Post: - 10th May 2008, 08:28
  4. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 00:39
