Displaying a decimal larger than 255 on LCD?
Results 1 to 11 of 11
    Oct 2008
    Default Displaying a decimal larger than 255 on LCD?
    Hello. Exactly as the title states.. how do I display a decimal larger than 255? I am storing a count in two bytes in an array and would like to display the 2 bytes as a decimal on the LCD which can be 0 - 65535?
    Thanks!
    Quote Originally Posted by djmachine View Post
    Thanks!
    Assuming using LCDOUT, and array elements are var[0] and var[1]
    dec var[1] dig 2, dec var[1], dig 1, dec var[1] dig 0, dec var[0] dig 2, dec var[0] dig 1, dec var[0] dig 0
    Might need a bit of a tweak, basically use the extension 'dig' to point to the digit of the 3-digit variable you wish to display. This will also display leading zeros
    Quote Originally Posted by Chris Barron View Post
    Deliberate mistake ;-).
    Var[0] can only hold up to 255 so as it stands it may not be quite correct to adopt that technique.
    What is the largest number you are using in each byte ? Does the lower byte count right up to 255 and then roll over, at the same time incrementing the higher byte ? Or, do you restrict the range of the lower byte to some other amount, such as 99 ?
    If you can't jump directly to extracting the values you need using the 'dig' directive, then you can always write a short math routing to count off the two bytes.
    sum var word
    lower var byte
    upper var byte
    sum = (upper * 255) + lower
    lcdout dec sum dig 4, dec sum dig 3, dec sum dig 2, dec sum dig 1 , dec sum dig 0
    May 2008
    Italy
    Should be:
    sum = (upper * 256) + lower
    Al.
    timmers's Avatar
    timmers Guest
    Thumbs up
    Could it not be as simple as:-
    COUNTER VAR WORD
    COUNTER_H VAR COUNTER.BYTE1 'high byte
    COUNTER_L VAR COUNTER.BYTE0 'low byte
    LCDOUT $FE,128,DEC4 COUNTER 'top row, position 1.
    Tim.
    Quote Originally Posted by timmers View Post
    COUNTER VAR WORD
    Tim.
    I don't think so, because although the LCDOUT is very simple and elegant, the maximum number which can be stored in either Counter_H or Counter_L is 255. Therefore the largest value which the word sized variable Counter can be is 255255.
    There needs to be a conversion first. The high byte needs to be multiplied by 256 (not 255 as I originally pointed out) and then added to the low byte before it gets stored in the word 'Counter'
    Wink
    COUNTER VAR WORD
    Tim.
    Hi, You were not so far ...
    COUNTER VAR WORD
    COUNTER.Highbyte = EEPROM_READ1    'high byte ( note: EEPROM_READ1 or value1, or ...xxx1)
    COUNTER.Lowbyte = EEPROM_READ2     'low byte
    No multiplying necessary ...
    California, USA
    Thanks!
    how about:
    MyWord = LowByte + HighByte << 8  ' Multiply HighByte by 256 (left shift 8) and add LowByte
    LCDOUT $fe,$1, MyWord
    Aratti had it right in post #4 I think, except I did it with leftshift instead of multiply by 256. Same thing...
  1. Play with LCD on PICDEM
  2. Need help with LCD number display.
  3. LCD will not start
  4. 32 bit data displaying on LCD
    By selahattin in forum mel PIC BASIC Pro
    Last Post: - 15th September 2006, 13:33
  5. 32 Bit Decimal Displaying On LCD
    Last Post: - 12th January 2004, 19:24
