MCP41XXX SPI Write
Results 1 to 5 of 5
    Do you have a pull-up resistor on PORTA.4?
    It has an "Open collector" output, and can't go HIGH by itself.
    Huntsville, AL
    Garsh, I think that's it. I knew there was something about one of the pins I was forgetting. I'll try that tonight and see what happens.
    So long as I use the CMCON=7 command, is porta.4 the only tricky pin I need to worry about? I also set the configuration byte to disable everything.
    Thanks!
  1. WRITE: One more PBP 2.60 Surprise ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 10:10
  2. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 05:08
  3. 16-bit SPI problem
    Last Post: - 19th June 2008, 16:42
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  5. Storing Strings using the Write command
    Last Post: - 1st November 2005, 12:31
