1 minute 30 seconds
Results 1 to 7 of 7
    Default 1 minute 30 seconds
    Hello,
    They can tell me how can I make a delay of 1 minute 30 seconds using this code. I have tried in various ways without any result.
    Thank you
    [HTML]CLEAR
    LED VAR GPIO.0
    CMCON = 7
    ANSEL = 0
    Include "Elapsed.bas"
    Gosub ResetTime ' Reset Time to 0d-00:00:00.00
    Gosub StartTimer ' Start the Elapsed Timer
    HIGH LED ; Start with LED on
    Loop:
    if MinutesChanged then
    MinutesChanged = 0
    if Minutes = 1 then LOW LED ; Turn off LED
    Goto Loop[/HTML]
    Default 1 minute 30 seconds = 90 seconds
    CLEAR
    LED        VAR GPIO.0
    Delay      VAR WORD
    CMCON = 7
    ANSEL = 0
    SecondsChanged = 0
    Delay = 90
    Loop:
      if Delay > 0 then
        if SecondsChanged then
           SecondsChanged = 0
           Delay = Delay - 1
           if Delay = 0 then LOW LED  ; Turn off LED
    Goto Loop
    CLEAR
    LED        VAR GPIO.0
    Delay      VAR WORD
    CMCON = 7
    ANSEL = 0
    SecondsChanged = 0
    Delay = 90
    Loop:
      if Delay > 0 then
           SecondsChanged = 0
           Delay = Delay - 1
    Goto Loop
    Hey Darrel,
    The code can also be used for hours and days?.
    Using HoursChanged or DaysChanged, sure can.
    Darrel,
    Thanks for your answer, I have further questions, I would like for example using three buttons change the hours, minutes and seconds for the LED turns off once the time. With this code can I do?.
    Thanks again
    Can you do it? Yes.
    Can you do it with that code? NO.
    Can you do it? Yes.
    Ok Darrel.
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
