CDC Assistance
Results 1 to 9 of 9
Thread: CDC Assistance
    Nov 2008
    Working for me here with a 18F2455.
    High likely an hardware problem, device programmer problem, or both.
    Install USBDeview, with it, uninstall the generated PIC18 USB CDC device, then reinstall the "driver".
    How would i know if it is a device or programmer problem (I'm using a JDM programer) http://www.instructables.com/id/Busi...IC-Programmer/
    and using a winPIC programmer software.
    And for the use of USBDeview, there is nothing there with regards to PIC18.....
    Nov 2008
    Also just thinking would there be a possible issue with the cdc code if the chip has less memory? since the PIC18F2450, the one i am using, has like half the memory of the PIC18F2455, the one that is working on your side?
    Quote Originally Posted by ricgar View Post
    Can you make the chip do anything, blink an LED?
    Some JDMs have trouble with 18Fs. JDM is not the recommended one here. To many troubles.
    Nov 2008
    Any other suggested DIY programmer?
    Not really, the only cheap one I would suggest is MicroChip PICKIT 2... but this is not a DIY.
    Maybe your Device programmer Software have an option to program or not program the configuration fuses? The led blink is usually a good start.
    Go with the PICKIT2. By the time you get the parts for a DIY kit, time spent trouble shooting why it does not work, visits to your therapist or local bartender. The $35 USD plus shipping is looking pretty good.
    I don't know if this could help in case it's a device programmer issue...
    http://members.aon.at/electronics/pic/picpgm/
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. USB CDC help..
    By jchandir in forum USB
    Last Post: - 22nd November 2008, 21:23
  3. Paid assistance needed, 16F877A, RS232, Vetra
    By CodeShredder in forum General
    Last Post: - 17th May 2008, 10:34
  4. CDC and Hardware Handshaking
    Last Post: - 9th November 2007, 05:08
  5. Microchip CDC Firmware with My OWN VID/PID ?
    By viewgsm in forum mel PIC BASIC Pro
    Last Post: - 8th June 2007, 02:33
