Calulating BJT base resistance for PIC led switching?
Results 1 to 12 of 12
Threaded View
  1. #2
    May 2008
    Italy
    Connect your NPN transistor with the emitter to ground then you can calculate the resistor in this way:
    R = (Vin - 0.7)/Ib
    Where:
    Vin = pic output (5 v)
    0.7 = base/emitter diode threshold
    Ib = desired base current ( 2mA is what you need for saturating 20 mA load)
    Nearest value = 2,2 K
    LM555 can be connected directly to 9 V PS and the output (pin 3) can drain your 20 mA load without any problem. So you can connect your led + 330 ohms directly to the IC.
    Al.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  4. LCD will not start
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 13:27
