GROUND plane or nor GROUND plane
Results 1 to 26 of 26
    Talking
    And ... as plating thickness is much less than copper thickness ...
    in the End ...
    North Norfolk UK
    in the End ...
    in the End ... depends on copper um/cost of etchant vs plating um/cost of solution
    AND.... shelf lives of each solutions.....
    _____
    xnihilo's Avatar
    xnihilo Guest
    It helped a lot Now I still don't know if my ground plane on the bottom side is fine or not (i removed the top layer ground plane). there's a program called EAGLE that creates the plane once you draw a polygon and name it like the ground on the board. Does it do it right or not? Hell if I know.
    A snapshot of the boards (when there were still a ground plane on both layers)
    http://users.edpnet.be/charlesetchri...0kit%20pcb.jpg
    By the way: I'm not using any RF device and my pic runs at 8MHz, 5V.
    North Norfolk UK
    Quote Originally Posted by xnihilo View Post
    It helped a lot there's a program called EAGLE that creates the plane once you draw a polygon and name it like the ground on the board. Does it do it right or not? Hell if I know.
    looking good.. well done
    turn off all the layers that you do not need to see and just leave bottom layer, then use the address label to "SHOW" your signal (whatever you have called it) and see the signal track it will shine brightly as a highlight, you will then see if the ground plane is cohesive. Its all down to wether when you created the polygon you used the setting "orphans", difficult for me to see in the jpg at the moment(on a mini machine) wether this is the case.
    You are better not to have orphans using a single ground plane , unless you are running out of ethcant
    cadsoft.de have a dedicated newsgroup, there is a lot there and they are very helpfull
    If you have 1 layer board then you dont put Ground Plane on the other side.
    If you want fast etching then use as much as possible Ground Plane.
    If you want to protect against EMI then use as much as possible Ground Plane.
    If you have double sided PCB, then
           If you want all the above then
           Endif
    Endif
    If you have RF then use as much as possible as much (again) Ground Plane
                use as much as possible Ground Plane and
                connect with vias as many times as possible.
           Endif
    Endif
    Conclusion:
    Always use as much as possible Ground Plane!
    North Norfolk UK
    Good Post Ioannis....
    ______
    xnihilo's Avatar
    xnihilo Guest
    "etching"???
    No rf used.
    Well, I think I'm safe, I'm using a nice GND plane on BOTTOM side.
    Thanks.
    Nov 2008
    If you have only GND Plane at the Bottom, and you forget to connect top layer assembled SMT components with their ground pad to the bottom layer, than you have a problem later...
    Best is always using GND Planes on top and bottom, reduces EMI, reduces the problem described above and it is more easy to use SMT components like QFN components with heatsink/gnd pad in the middle. You only need to make some more extra gnd vias along the board outlines, thats important not to get later some dirty effects (More important in rf layouts). Keep attention not to get isolated areas also!
    Ralf
    "etching"???
    No rf used.
    Thanks.
    OK, OK, I know. I am not fluent in English. Sorry.
    xnihilo's Avatar
    xnihilo Guest
    Quote Originally Posted by duncan303 View Post
    Yes, thanks
  1. A PIC logic 0V output is not equal to a ground?
    Last Post: - 17th November 2009, 19:47
  2. Connecting circuit ground to mains ground
    Last Post: - 12th November 2009, 23:02
  3. Etching and ground planes
    By DavyJones in forum Schematics
    Last Post: - 9th April 2009, 19:16
  4. Negative Numbers/Virtual Ground
    By scottl in forum General
    Last Post: - 7th May 2006, 22:35
