semaphore pic12f629
Results 1 to 27 of 27
    That is doable. If GP4 is LOW, making GP0 or GP1 or GP2 High will make the connected LED light. The same for GP5.
    Being I do not know the sequence you want them to light here is an idea.
    Your code will have the "blinking" sequence with multiple pauses. The value of the pauses will be held in a variable. A button will connect to GP3 as an interrupt. Every time the button is pushed the variable will increase by the amount you want. Once the highest value is reached the variable will reset to the lowest.
    "VARIABLES
    X VAR WORD:Y VAR WORD:Z VAR WORD
    ON INTERRUPT GOTO MYINT
    INTCON=%10001000
    IOC = %00001000
    'YOUR SEQUENCE
    DISABLE
    MYINT:
    IF GPIO.3 = 1 THEN
        X = X * 10
        Y = Y ???
        Z = Z  ???
    IF  X =>  ? THEN X  =  ??
    IF  Y =>  ? THEN Y  =  ??
    IF  Z =>  ? THEN Z  =  ??
    INTCON.1 = 0
    RESUME
    ENABLE
    Maybe something like that will work for you.
    "VARIABLES
    INTCON=%10001000
    IOC = %00001000
    'YOUR SEQUENCE
    DISABLE
    MYINT:
    IF GPIO.3 = 1 THEN
        X = X * 10
        Y = Y ???
        Z = Z  ???
    INTCON.1 = 0
    RESUME
    ENABLE
    Hello,
    This is a sequence that desire for the lights.
    May 2008
    Italy
    You can accomplish the result with only 3 output ports. Connect Red led A and Green led B from port one to ground; Green led A and Red led B from port one to + 5V (pay attention to the polarity). Yellow led A to port 2 and Yellow led B to port 3. When Port one is High the green/red leds (correctly polarized will lit) when port one will turn low you will switch on the second set of green/red leds.
    With port 2 and 3 you modulate the yellows.
    Quote Originally Posted by Leonardo View Post
    Are you sure about that sequence?
    Don't they normally go Green-Yellow-Red?
    Yes, but it looks like it's backwards.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2968" />
    Darrel sequence can be changed later by now we can start the code to get an idea of the operation, which you suggest?.
    Well, ok.
    But I accept no responsibility for the resulting accidents.
    @ device  INTOSCIO, WDT_OFF, PWRT_OFF, MCLR_OFF, PROTECT_OFF, CPD_OFF
    DEFINE OSCCAL_1K 1
    Green         CON 5000             ; mS to show Green Light
    Yellow        CON 1000             ; mS to show Yellow Light
    Tcalibrate    CON 480              ; Adjust for loop timing accuracy
    Sequence      VAR BYTE             ; cycles through the 4 states
    TimeCount     VAR WORD             ; Counts down sequence time
    CMCON = 7                          ; Disable comparator
    GPIO   = %110000                   ; Start with all LED's off
    TRISIO = %001000                   ; Set LED ports to output
      FOR Sequence = 0 to 3
        LOOKUP2 Sequence,[ Green,  Yellow,  Green,  Yellow], TimeCount
        REPEAT                                                   ; Multiplex
          LOOKUP Sequence,[%100001,%100011,%100100,%100100],GPIO ;  Tr. Light #1
          PauseUS Tcalibrate
          LOOKUP Sequence,[%010100,%010100,%010001,%010011],GPIO ;  Tr. Light #2
          PauseUS Tcalibrate
          TimeCount = TimeCount - 1
        UNTIL TimeCount = 0
      NEXT  Sequence
    GOTO Main
    Last edited by Darrel Taylor; - 4th November 2008 at 03:24. Reason: added OSCCAL_1K
  1. pic12f629 EEPROM problem in MPLABSIM
    By nicholastyc in forum General
    Last Post: - 16th May 2008, 18:10
  2. PIC12F629 - OSCCAL LOST in combat
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 28th March 2007, 21:06
  3. Ultrasound with PIC12F629
    Last Post: - 28th February 2007, 16:22
  4. PIC12F629, useing all I/O pins
    By Jcee324 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2004, 11:05
  5. PIC12F629 or 8pin
    By andyf in forum mel PIC BASIC Pro
    Last Post: - 27th October 2004, 18:11
