Accessing Portion of Input Port
Results 1 to 11 of 11
    Aug 2008
    Default Accessing Portion of Input Port
    I have PortA on an 18F8722 defined as an input port , and I want to read 3 of these pins at once. Say I want to read 0,3,5 and use the input in an IF statement is this possible?
    Jun 2007
    Mansfield, UK
    You can check for a state on all 3 pins with one if statement if thats what you mean
    if porta.0=1 and porta.3=1 and porta.5=0 then
    In that example 0 and 3 must be high and 5 must be low to execute the code in the if statement
    Aug 2008
    I know I can do it that way I was just looking to do it with out the and satements... so I can say something like:
    IF PortA135 = $6h then
    Quote Originally Posted by Frozen001 View Post
    IF ( PortA AND %00101001 ) = $29 (in this case all bits must be logic high) THEN whatever
    Or are you talking about pulling out PortA. bits 1, 3, and 5 (or whatever) and putting them in temp. bits 0,1,2 ???
    Jun 2007
    Mansfield, UK
    That is also possible. You can use the bit AND operator (&).
    if (porta & %00010101)=%00010101 then
    The purpose of (porta & %00010101) is to strip out the unwanted information. Only the bit where you see a 1 will be kept from porta. Then you compare that with the value you are looking for
    Edit: Looks like skimask got there before me!
    Quote Originally Posted by The Master View Post
    MMMMWWWWAAAAHAAAAAA!!!!!!
    (don't know if you guys do much for Halloween over there or not...but there it is )
    Jun 2007
    Mansfield, UK
    Have you seen half my threads?!?! I dont think many people celebrate it here but i sure do Its my fave time of the year
    I do a little morphing this time of year too.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2931&stc=1&d=122486118 8">
    Jun 2007
    Mansfield, UK
    Is that going to be your new avatar for next week?
    Thinking about it, i should get an avatar for halloween!
    I can not figure out how to up load an animated avatar. But that is what I was thinking.
    Jun 2007
    Mansfield, UK
    Your limited to 19.5K so that one is too big. Im sure someone here has an animated avatar already
  1. Input and Output on same Port
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 13th November 2008, 19:46
  2. Microcontroller with 2 way paging application problem
  3. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  4. Can defines be changed with port input?
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 23:50
  5. Duplicating port input to port output
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 22:43
