Reading, writing, erasing flash (16F88)
Results 1 to 27 of 27
    Omaha, Nebraska USA
    Now I get it; you're testing me, right?
    No need for that...
    Doggone--I see I kept thinking decimal 10 (%1010) and typing $10 (%10000) instead of $A. How in heck did I manage to do that? I've corrected the posts, but why didn't you catch that and save me from raging embarrassment?
    As the Shadow says, "Who knows what evil lurks in the hearts of men?"
    I can't believe that absolutely no one else has chimed in on this topic, though.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    May 2007
    Quote Originally Posted by RussMartin View Post
    ....I can't believe that absolutely no one else has chimed in on this topic, though.
    Possibly because PIC16's are not really designed to do what you have in mind. Of 93 PIC16's that are listed on MicroCHIP's website, only 6 have self-write capability (which is what allows you to do what you trying to do). OTOH, of 155 PIC18's, 135 of them have self-write. AFAIK, ALL 24-bit core devices (PIC24F/H, dsPIC30 and dsPIC33) have this capability - which I have used on many occassions. You may want to take a look at this App note:
    AN1095, Emulating Data EEPROM for PIC18 and PIC24 MCUs and dsPIC DSCs
    http://ww1.microchip.com/downloads/e...tes/01095b.pdf
    Sep 2005
    Campbell, CA
    OK, I'll add my $.02
    I have done this - but only with an 18F8722. I used ERASECODE on a 64byte boundary, then issued 32 consecutive word-size WRITECODEs
    It worked.
    Charles Linquist
    Omaha, Nebraska USA
    Possibly because PIC16's are not really designed to do what you have in mind. Of 93 PIC16's that are listed on MicroCHIP's website, only 6 have self-write capability (which is what allows you to do what you trying to do). OTOH, of 155 PIC18's, 135 of them have self-write. AFAIK, ALL 24-bit core devices (PIC24F/H, dsPIC30 and dsPIC33) have this capability . . .
    Thanks for the suggestion. Yes, I am aware that, according to the online chart, only 6 of 99 16-series devices (the '88 and the members of the '88x family) have the capability. The 16F88 was recommended to me by another member of this forum as a good starting point for what I want to attempt since I was looking for a quick alternative to using EEPROM in a '648A.
    Charles, good to hear from you again! That's the kind of clear, concise information I appreciate. I'm going to do an empirical test of my trial hypothesis with a similar approach on a 16F88 using a counter and loop now that I have some sort of concept of what's going on "under the hood" and why.
    Russ
    Actually, there are 20 16F's that can write to their own flash memory.
    But there are 5 different methods, depending on the chip in use.
    After your first post, I started making a Flash movie, to show how to write to flash on a 16F88. And before I could even finish the first frame, this thread had already entered the "Confusion Zone", very similar to the "Twilight Zone".
    So I decided to expand it to include all the 16F's. Big mistake, takes too long. Should have stuck with the 16F88. Here's one of the frames which shows the different varieties. At that point the flash splits into 6 different explanations. 16F88 is #6.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2926" /><!-- Name:  FlashChips.JPG
Size:  34.7 KB -->
    It'll take too long to finish to be of help to you, and I don't think you are any closer to writing to flash on a 16F88, so I'll try to put it in Words.<hr>
    The only thing to really worry about, is that the Write to Flash only occurs when you write to the 4th word in the Block. Writing to the previous 3 words, only places the data in "Holding Registers".
    For instance, the following code which attempts to write to the 1st word and read it back ...
    FlashAddr  VAR WORD
    FlashData  VAR WORD
    FlashAddr = $800
    FlashData = $123
    WRITECODE FlashAddr, FlashData
    READCODE  FlashAddr, FlashData
    Will return $3FFF in the FlashData variable, because the data was never written.
    However, this code ...
    FlashAddr = $803
    FlashData = $123
    Would return $123, because it wrote to the 4th word of the block.
    If you wanted to only write data to the First address, then you must also write data to the 4th address. If the 4th data is $3FFF then nothing actually gets written to that location.
    So this code ...
    FlashAddr = $800
    FlashData = $123
    FlashAddr = $803
    FlashData = $3FFF
    FlashAddr = $800
    Will return $123, and only 1 Word has been written to memory.
    How do you know if it's the 4th word of the Block?
    By the Lowest 2-bits of the address. If they are both 1's then it's the 4th.
    Therefore, it's easy to make a subroutine to write a single word anywhere that's free.
    WriteFlashWord: ; Set FlashAddr and FlashData before calling (Vars are Destroyed)
        IF (FlashAddr & %11) != %11 THEN
            FlashAddr = FlashAddr | %11
            FlashData = $3FFF
    The chip should be Erased when it's programmed, so you only need to ERASECODE, if you need to overwrite the data.
    HTH,
    Omaha, Nebraska USA
    Thumbs up
    Darrel, much thanks.
    As always, you present a lucid, wonderfully informative yet concise solution. I printed a copy of your post and stapled it facing page 32 of the 16F88 data sheet. (My printed copy isn't duplexed.)
    I hope you will give thought to finishing the tutorial covering writing to flash for all of the 16F devices and posting it either here or on your own web site. It would be a valuable resource.
    And, of course, my apologies for straying into the Confusion Zone. "Who was that masked man?"
    If I'd seen your post sooner, I'd have saved myself the frustration (i.e., "learning experience") of my insufficiently informed empirical test . . . which, of course, returned nothing but $3FFF from every location! I did a similar loop with your guidance . . . which, of course, works as if charmed.
    Russ
    This thread put me in some thoughts about updating the firmware from a remote station.
    Is it possible to replace the existing firmware of a PIC with new one?
    And souldn't there be some kind of bootloader for this purpose?
    May 2007
    The problem with this boot loader is that your code is not protected and anyone can copy it.
    With Writecode commands, things might be different.
    Omaha, Nebraska USA
    Smile
            FlashData = $3FFF
    The chip should be erased when it's programmed, so you only need to ERASECODE if you need to overwrite the data.
    This works like a dream!
    Thanks, Darrel!
    Russ
  1. Writing & Reading to iButton EEPROM
    By crhomberg in forum Code Examples
    Last Post: - 6th October 2008, 20:40
  2. Writing and reading to a 24LC1025
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 20th April 2007, 12:49
  3. reading, writing, and displaying from eeprom
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 23:05
  4. 16F88 reading Analog Input
    By thunderstrike44 in forum mel PIC BASIC Pro
    Last Post: - 30th August 2004, 23:41
  5. Writing / Reading EEPROM 24LC256 Problem
    By schmoddel in forum mel PIC BASIC Pro
    Last Post: - 27th February 2004, 19:55
