revolution counter
Results 1 to 30 of 30
    Sep 2006
    I got the circuit working now without the ADC, thats the one I will use.
    BUT,I also tried the ADC, it only works in 10 bit mode when I try the 8 bit mode, nothing appears on the LCD. Here the progrm, but before here is the two lines I changed for the 8 bit mode:
    ADCON1 = %10000010
    Define ADC_BITS 8 ' Set number of bits in result
    why is this happening?
    INCLUDE "modedefs.bas" 'Includes supoprt for PicBasic language
    @ DEVICE pic16F88, INTRC_OSC, CCPMX_ON
    OSCCON=$60 ' use internal 4MHZ osc
    ANSEL = 0
    CMCON = 7 ' Turn OFF the comparators so pins can be used as digital I/O-pins
    ADCON1 = %00000010 ' Analog to digital configuration register (ADCON)
    ' Set PORTA to digital
    ' Define ADCIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    ADCON1 = %10000010 ' Analog to digital configuration register (ADCON)
    '// LCD configuration //
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 1 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 0 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    '// PIN configuration //
    TRISA = %11100111 ' Set PORTA to all input
    TRISB = %00001100 ' Set PORTB to all output
    PortA = 0
    '// Variable Declaration and initialization //
    Output_Pot var byte
    OldOutput_Pot var byte
    Revolution var word
    counter var byte
    revolution = 0
    Output_Pot = 0
    OldOutput_Pot = 0
    counter = 0
    'Get initial value
    'ADCON0.2 = 1 'Start Conversion
    ADCIN 1, OldOutput_Pot 'analog pin 1 (RA1) get the 8 bit result
    pause 50
    if OldOutput_Pot > 512 then
    OldOutput_Pot =1
    OldOutput_Pot =0
    Mainloop:
    ADCIN 1, Output_Pot 'analog pin 1 (RA1) get the 8 bit result
    pause 50
    'Calculate the distance
    if Output_Pot > 512 then
    Output_Pot =1
    Output_Pot =0
    if OldOutput_Pot == Output_Pot then
    goto Mainloop
    if OldOutput_Pot != Output_Pot then
    counter = counter +1 'If oldOutput_pot is different then Output_pot
    OldOutput_Pot = Output_Pot
    if counter =4 then
    Revolution = Revolution + 1
    counter =0
    lcdout $FE,1, "Counter:",dec counter
    lcdout $FE,$C0, "Revolution:",dec Revolution
    pause 150
    GOTO Mainloop
    Quote Originally Posted by lerameur View Post
    Did you set it for left justify or right justify? Makes a difference...
    Sep 2006
    it is in the code above:
    with this it works:
    ADCON1 = %00000010
    but not:
    ADCON1 = %10000010
    Right, with one you're putting the 10 bit value (justified left) into a byte, with the other, you're putting the 10 bit value (justified right) into a byte, trying to stuff 10 bits into a spot for 8 bits.
    So, with one, you get the lower 8 bits of the 10 bits, with the other you get the upper 8 bits of the 10 bits.
    Which one is it? That's for you to figure out....(hint: if you use a word variable for reading, you'll figure it out quickly if you also use the LCD to display that value)
    Sep 2006
    I am using the same config as the sample program on melabs:
    http://www.melabs.com/resources/samples/pbp/adcin8.bas
    as you can see mine is not working.
    k
    k
    Except that they're using 8 bits and a byte, and you tried using 10 bits and a byte.
    (hint: see the hint above about the hint in post #25)
    Sep 2006
    oups, ok i was sleepy last night,
    thanks for your help
    ken
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Counter not counting !!!
    Last Post: - 20th February 2009, 23:15
  3. Replies: 42
    Last Post: - 14th January 2008, 12:38
  4. 20 Digit Virtual LED Counter
    Last Post: - 19th November 2007, 06:02
  5. Microcontroller with 2 way paging application problem
