servo motor resets 16f877a
Results 1 to 40 of 86
    Sep 2008
    Hi guys,
    I bought 9v 3.5 A power supply but Only problem that i have "vibration" is still same...
    It is so weird,up-down motor vibrates only some values....
    I dont know what to do but I think I gotta take off up-down motor...
    Maybe these values are limits of servo as skimask said...
    I will connect up-down motor to left-right motor with different way so I can use values which didnt make vibration for up-down motion....
    Thats the only solution that I can find...
    Any other ideas????
    Quote Originally Posted by burak450 View Post
    Have you changed the regulators also? To handle the extra amps...
    Have you tried laying the apparatus on it side to see if the up/down servo works correctly?
    Any other ideas????
    Have you tried counter balancing the up/down servo?
    Ok we are getting somewhere now. No reset.... Vibration is an indication that the servo is having trouble settling to a position. Mackrackit is pointing you in the right direction, you need to somehow balance the structure or unload it.
    Think of a way to keep the weight of the turret from sitting directly on the servo shaft. The shaft of a servo is geared to a potentiometer which means anything that back drives the servo shaft will alter the potentiometer. That leads to vibration (or low level oscillation). The idea is only to use the servo to move, not bear the weight of the structure. Beyond that there is really no more that anyone can do for you, the structure mechanics is the issue now.
    Nick
    Sep 2008
    Hello everyone..
    I solved the problem.Servo doesnt reset itself now...It was because of code...
    Servo doesnt vibrate now..I changed the motor and bought an expensive one.the only problem was my cheap and broken servo...
    Thanks everybody who helped me....
    Hello everyone..
    What part of the code did you change to fix the problem?
    Broken servo - well, ok, it happens, hasn't happened to me yet, sure, could happen. It's just that everything you suggested pointed right to a power issue.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 08:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 09:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 19:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 21:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 18:15
