Can an led be controlled by analog pin?
Results 1 to 7 of 7
    Is it possible to control an led (+5V output) using a pin that is set to analog?
    Yes, it's possible. But the technique required depends on how you are using the other Pins on PORTA.
    Pins in analog mode can be put into output mode, and they will work just fine as long as no other Pins on that port are used for Digital input.
    If another pin is using Digital OUTPUT, then a holding register can be used to eliminate the Read part of Read-Modify-Write.
    If RA4 is an input to T0CKI, then that isn't considered a Digital input as far as R-M-W goes.
    And yes, you can re-configure the analog ports "on-the fly", but that won't take care of the R-M-W problem if any of the pins are Digital INPUT.
    What are the other pins on PORTA used for, and what is your current ADCON1 setting?
    Nov 2004
    Calabasas, CA
    I had thought about continually flipping the ADCON1 register, but wasn't sure about the effect on everything, my continuous ADC, flickering led, etc.
    No other pins on that Port are used as digital input. All PORTA pins are analog, (2) are used as ADC input. (RA4 is an input to T0CKI)
    ADCON1 =0
    Thanks for the input.
    James
    Ok, so there are 4 analog pins, they are all in analog mode.
    You are using 2 of them for analog input and want to use 1 for digital output.
    That leaves 1 analog pin unaccounted for.
    Is that one an OUTPUT too?
    It makes a big difference.
    If not, and it's just not being used, then you can use HIGH and LOW like normal on the pin with the LED.
    If that other pin is also an output, you'll need to use a variable as a Latch (holding reg) to fix the R-M-W issue.
    Nov 2004
    Calabasas, CA
    Yes, TRISA =011X
    A.0 is only used for an LCD output for testing, and is normally necessary. I can live without it.
    James
    James
    Thumbs up
    Yes, TRISA =011X
    Ah Ha! Makes perfect sense now.
    You're "good to go".
    Cheers,
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  3. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
