If the checksum value was received with its original value, and keydata1-6 are scrambled then the sum would not be equal to the value of checksum, the outcome would be datagood = 0 since keydata1-6 != checksum. That's what one would want to happen.
I was just wondering if per say 4 keydata's out of 6 were equal then assuming their value is correct, could one say reject the last two scrambled keydata's and run. What I mean is if there were a way to say I sending six keydata's if four of any of the six match consider the data good and run. That would allow for pressing the button on the tx and allowing for multipath rf and reflection problems, and prevent from instead of the output chattering on/off but to remain on until the transmitter output is off.
By the way am I correct that the maximum size I could make keydata or address to send out or receive throught serial would be byte size, 8bit ,on the 16f628a?
