Code Timer - How long does it take to execute XYZ command?
Results 1 to 6 of 6
Threaded View
    May 2006
    Del Rio, TX, USA
    Default Code Timer - How long does it take to execute XYZ command?
    Since this question has come up again, I thought I'd throw this module out to the masses. It is something I worked on a while back, with DT's help. Amid life's other priorities, it got put on the self to collect dust.
    The basic idea is that by adding the module as an INCLUDE and inserting a couple of commands inside your code, you can have the PIC send timing data to your PC via the hardware serial port. It's make for 18F PICs (although some 16Fs may work too). You also need a timer that is not being used for anything else.
    1) Instructions are included, as well as a small example.
    2) It worked well for me, and as I recall, DT in testing.
    3) Use it however you want.
    4) I won't be able to offer much support, but figure there are enough knowlegeable folks around here that can help those who need it.
    Best Regards,
    SteveB
    Thanks Darrel for all your help!
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 09:02
  2. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  3. Making Program Code Space your playground...
  4. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 22:05
  5. Timer Accuracy
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 05:26
