This may not find favour with the experts, but you could try this code. No interrupts
The grain here is 1mS between samples of the inputB which I guess should be overkill for a photography application if InputB is a manual push buttonCode:Counter var byte for Counter = 1 to 500 ' 500 mS time to find inputb pauseus 1000 ' pause a millisecond. You may need to trim this value if InputB then ProcessB next ' ..... do code following 500mS timeout of not getting InputB return ' to wherever ProcessB: ' do whatever you want here. You could also tell after how long InputB has come by reading the value of the Counter which counts in 1mS increments return
